Yamaha DT 125 problem
dirtydt
PostPosted: 22:53 - 29 Mar 2015    Post subject: Yamaha DT 125 problem Reply with quote
I own a yamaha dt 125 2003 the model with the 2 stroke oil pump, basically my bike is running okay but it doesn't go as fast as it should the power band is not as pokey as it was before, however when i go for a day of off roading and revving the bike really hard and generally getting fairly hot the bike absolutely flys for a week or so and then starts to go slower again! What is wrong with it? My thought is that the 2 stroke pump is running a bit too rich causing the power valve to not open properly and then after riding off road and really revving the bike and it getting fairly hot for a good few hours it burns off all the built up 2 stroke? What is your opinion? also when i was off roading yesterday my bike really spluttered at about 7-8000 revs (power band) and wouldnt rev any higher, it did this for 10 minutes or so and then began to run fine again
PostPosted: 23:23 - 29 Mar 2015    Post subject: Reply with quote
Sounds like the exhaust is full of carbon.
dirtydt
PostPosted: 23:25 - 29 Mar 2015    Post subject: Reply with quote
but why would the bike run better after being thrashed?
Suntan Sid
PostPosted: 23:52 - 29 Mar 2015    Post subject: Reply with quote
You've burned some of the carbon away!
Look up "Italian Tune Up".
PostPosted: 08:17 - 30 Mar 2015    Post subject: Reply with quote
Yep, I've seen a bike that wouldn't rev at all from being clogged up. remove the exhaust pipe and take a look inside the pipe and inside the exhaust port.
dirtydt
PostPosted: 12:56 - 30 Mar 2015    Post subject: Reply with quote
how do you suggest i clean it?
Suntan Sid
PostPosted: 14:00 - 30 Mar 2015    Post subject: Reply with quote
Usually involves some rubber gloves and caustic soda!
Google "Decoke two stroke exhaust".
The last post was made 10 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 53.06 Kb
