| Davenaylor |
 Davenaylor Crazy Courier
 Posted: 13:07 - 30 Mar 2015 Post subject: Callipe clean up - Can I rescue these without splitting them |
As per the subject, I have just taken the Callipers off the disks as they are sticking when left stationary. I have received the following advice on bikers oracle:
| Quote: | You shouldn't need new seals, nor do you need to go to the extreme of the Bowl of mice strip and clean. Just a clean up should do it. Remove the caliper from the bike, keep the brake hose connected. Remove the pads, you will see the four pistons. Work the brake slowly, one piston will start to move outwards. You have to be very careful not to pop the pistons all the way out, but it is possible to ease them forward one by one, I'd say by 10mm just to be safe. clean all the crud off the sides of the piston with a clean cloth, then gently press it back in, making sure the other three dont move out as you are doing this. It's a bit of a juggling act, a disk brake thickness block of wood is useful to keep two pistons secure whilst you pump out, press back the other two .. I also use a small amount of grease on the piston sides once it's pushed out, has to be Red Rubber grease though, its specially for Brake pistons. This helps to keep the piston sliding free for longer by lubricating the dust seal and providing a bit of a barrier for water ingress. |
and
| Quote: | What Trumpet said, but be very careful not to push the pistons right out on an ABS model. If you lose too much fluid you'll have to bleed the whole system & that requires special Triumph tools & software to fool the ABS seonsors that nothing untoward has happened. That software is not included in the Tune ECU software. |
Before I attempt this I wanted to ask if its worth it based on the picture linked to here (sorry the quality is rubbish!). https://drive.google.com/folderview?id=0B1WfLGfFqSQ8U1ptbE5YcTI1TXM&usp=sharing
Or am I looking at splitting them and doing a full refurb.
Bike is an 05 Sprint ST 1050 ABS model
On the plus side, looking at the pics my brakes should be good once i'm done.
thanks |
| bladeblaster |
 bladeblaster Trackday Trickster
| mentalboy |
 mentalboy World Chat Champion
| Davenaylor |
| bladeblaster |
| cheeseman |
 cheeseman Trackday Trickster
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 20:58 - 31 Mar 2015 Post subject: |
Just do the bowl of mice thing  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| kramdra |
 kramdra World Chat Champion
| Davenaylor |
The last post was made 11 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
