bleeding brakes on a multi pot piston and combi brakes
andyscooter
PostPosted: 08:23 - 31 Mar 2015    Post subject: bleeding brakes on a multi pot piston and combi brakes Reply with quote
right parts are fitted and am now ready to bleed my brakes
normal single front and rear is easy but how do you go about bleeding them when
the front and rear lever work the front caliper (two lines and two pots with two nipples Embarassed
and then a separate line to the rear one that also works off the rear lever
this is on my burgman still
Taught2BCauti...
PostPosted: 09:06 - 31 Mar 2015    Post subject: Reply with quote
If you can't find the recommended procedure in the manual, I would start by bleeding from the furthest point away from the master cylinder first, and work your way back.
Some braking systems suggest that you bleed backwards - forcing fluid through the bleed nipples, and syphoning the master cylinder as it fills up.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 10:20 - 31 Mar 2015    Post subject: Reply with quote
Too much magic. I never managed to get the front on my Burgman fully hard (leave it) after replacing the pads. Fortunately, the rear/combined was excellent and it still stopped harder than anything I had before or since.
I didn't try reverse bleeding it though, but I'm now mega gay for that method so would suggest giving that a go. Rear first, most likely.
bladeblaster
PostPosted: 11:06 - 31 Mar 2015    Post subject: Reply with quote
I had a X11 with linked brakes, total nightmare, took it to dealer in the end and they did it. I got it ridable, but spongey as shit.
PostPosted: 11:46 - 31 Mar 2015    Post subject: Reply with quote
Oh, while I remember, the rear piston is one of those freaky wind-in jobs like on cars. I totally did not wrap a rag round it and use grips to wind it in.
andyscooter
PostPosted: 12:10 - 31 Mar 2015    Post subject: Reply with quote
Havnt touched rear claiper as pads are fine
The last post was made 11 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 47.91 Kb
