Direct injection Two Strokes
STONEY!
PostPosted: 16:32 - 31 Mar 2015    Post subject: Direct injection Two Strokes Reply with quote
Why havent we got any? Seems to be old tech when it comes to outboard motors, surely would work well in a bike?
PostPosted: 16:41 - 31 Mar 2015    Post subject: Reply with quote
Emissions.
temeluchus
PostPosted: 17:23 - 31 Mar 2015    Post subject: Reply with quote
Probably no way to get around loads of partially combusted two stroke oil being pumped out the exhaust.
STONEY!
PostPosted: 17:44 - 31 Mar 2015    Post subject: Reply with quote
The whole point of direct injection 2 strokes is that the emmisions are low and fuel economy is improved as well.
A normal 2 stroke throws fuel/oil out of the exhaust port every cycle whereas a DI two stroke injects exactly the right amount at the right time.
pepperami
PostPosted: 18:15 - 31 Mar 2015    Post subject: Reply with quote
I believe that Lambreta Scooters were working on a direct injection two-stroke engine a few years ago??
Would`nt it be nice to have a few more strokers on the road Smile
PostPosted: 18:38 - 31 Mar 2015    Post subject: Reply with quote
Euro4 comes out in 2016 for bikes, I very much doubt a 2 stroke could meet it as from what I have heard it is a BIG change for four strokes.
blurredman
PostPosted: 18:40 - 31 Mar 2015    Post subject: Reply with quote
I never did hear any development from this..
https://www.cycleworld.com/2012/08/13/two-stroke-resurrection/
temeluchus
PostPosted: 19:03 - 31 Mar 2015    Post subject: Reply with quote
Oil is still sprayed into the crankcase to lubricate the bottom end and is still part of induction. Whilst direct injection does clean things up it still doesnt eliminate it.
Dont confuse a direct injection two stroke with the likes of a diesel two stroke. The only way to eliminate the need for total loss lubrication of the bottom end is forced induction.
PostPosted: 20:32 - 31 Mar 2015    Post subject: Reply with quote
There have been a few. Aprilia with a scooter and Bimota with the Vdue. Honda also had a few off road bikes.
Think part of the problem is that bike engines rev fairly high and it is difficult to cycle the high pressure injection system quickly enough for that (especially when it needs to inject fuel every turn of the crank).
Would be possible to seal the bottom end bearings from the mixture (both mains and big end). However you still need lube for the cylinder walls. But not that much, and if properly delivered (rather than just dumping a load in with the incoming air and hope a bit of it hits the cylinder walls) only a tiny amount.
Think the Aprilia Ditech scooters just used a blower though.
Mudshark
PostPosted: 21:13 - 31 Mar 2015    Post subject: Reply with quote
yeh, I remember this with bimota
https://www.odd-bike.com/2012/11/bimota-v-due-500-bike-that-killed-bimota.html
as an oldie who had his fair share of t-stokes, I miss the hooligan element even now
R1250RS
XT660X
temeluchus
PostPosted: 05:49 - 01 Apr 2015    Post subject: Reply with quote
They used a little electric blower and indirect injection. I dont know how well that would scale to a larger engine.
PostPosted: 07:27 - 01 Apr 2015    Post subject: Reply with quote
Two strokes in diesels is a completely different kettle of fish to 2 stroke petrol.
We have large, low reving 2 stoke diesels in the marine industry but they are basically normal diesels running a 2 stroke cycle.
By that I mean the have normally lubricated sumps, turbo blown charge air, quite often running an exhaust valve rather than ports, and fuel injections so there are no unburnt oils going out with the exhaust.
I don't know if that set up would be even possible in a bike petrol engine.
stevo as b4
PostPosted: 16:20 - 01 Apr 2015    Post subject: Reply with quote
The normal two stroke diesel operating principle would be to heavy and too complicated for bike engines, even in petrol applications, as by adding all the extra bulk and parts, you may as well have a 4stroke engine instead.
I agree that DI two strokes for bikes got as clean as they were ever going to with the Aprilia Ditech etc. As Temelucus and Keith said, you still needed some oil (not nearly as much as std 2strokes) spraying into the air inlet to lube the motor. MPG is good with Di, and efficiency, but burning a little bit of oil constantly and deliberately is not so good, and would probably ruin any catalytic converter's that would be fitted, quite quickly.
The Marine outboards are about the last employer of DI strokers' but they get away with tiny amounts of oil added for a few reasons, one of them is the environment the exhausts dump into, and outboards could run 150-200:1 oil ratio's.
Also like Keith said the technology to switch very high pressure injectors on and off quickly enough for more rpms and bigger cylinders does not work very well. I'm sure Aprilia were quoted as saying that 125cc was the realistic limit for Ditech injection technology.
Also something I wasn't aware of until Iain said, was how badly Ditech systems on the SR50 have fucked up after a few years and needed really expensive spares to fix, making them un-popular and un-trusted as they get older and have faults. Then again 50cc Ped's were as much about how easy they were to tune, and how well they ran at 70cc with all the fancy parts added. I didn't think the Ditech's were very tunable in that sense and it was hard to re-map them or up the fuelling enough for high end tuning conversions, so they were not that well received.
Indirect two stroke injection works at least as well as carbs, and does offer some emissions and mpg benefits, but nothing like DI can.
Even new petrol car engines are all having to be DI designs now, if you want say a 2.0 petrol that makes 220bhp and still does over 40mpg. That would have been impossible 15years ago!
onefourk
PostPosted: 17:15 - 01 Apr 2015    Post subject: Reply with quote
Why does a DI two stroke need any oil in the inlet charge?
temeluchus
PostPosted: 17:39 - 01 Apr 2015    Post subject: Reply with quote
Because without forced induction, the crankcase has to be used for a pump. This means the bore and crankshaft/rod bearings will go unlubricated unless oil is sprayed into the crankcase which is part of a two strokes inlet tract.
onefourk
PostPosted: 19:34 - 01 Apr 2015    Post subject: Reply with quote
Ahh, with you. In my mind I assumed some sort of supercharging would be part of the deal but I guess it ain't necessarily so. Thumbs Up
PostPosted: 23:10 - 01 Apr 2015    Post subject: Reply with quote
Uses a blower to further compress crankcase air and mixes that with the fuel, which is then squirted directly into the cylinder head.
K
The last post was made 11 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 103.31 Kb
