oil sitting in air filter housing
sutty86
PostPosted: 23:44 - 31 Mar 2015    Post subject: oil sitting in air filter housing Reply with quote
Got a derbi Terra just changing oil and air filter and found this oil sitting in the housing
Surely not right is ithttps://i.imgur.com/Aol2GUf.jpg[/img]
Nemo
PostPosted: 23:58 - 31 Mar 2015    Post subject: Reply with quote
I can't tell how much is actually in there, but the crankcase breather goes into the airbox, so I wouldn't worry too much.
A lot of airboxes have a drain on the bottom, have a look see if yours does (usually a tube with a bung on the end)
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
SQL
PostPosted: 00:02 - 01 Apr 2015    Post subject: Reply with quote
mine did that too, there is a bung at the bottom of the air box it does get blocked so I drilled mine the next size up
sutty86
PostPosted: 00:57 - 01 Apr 2015    Post subject: Reply with quote
Cheers ,cleaned it out with tissue, I can see a rubber bung further down towards the carb/engine but looks as dry as a nun
sutty86
PostPosted: 00:58 - 01 Apr 2015    Post subject: Reply with quote
Tried changing oil what a bastard it is!!!
Think I need 23/24mm socket as can't get a wrench to it without taking engine guard and gear lever off!!!
[urlhttps://www.derbimotorcyclespares.co.uk/genuineparts/10604/13/derbi%20terra%20125%20adventure%20e3/filter%20box?uid=0[/url]
Presume no.3
Northern Monkey
PostPosted: 08:29 - 01 Apr 2015    Post subject: Re: oil sitting in air filter housing Reply with quote
Oil in the airbox most commonly occurs if you fill the engine with too much oil. Make sure you have the bike level when checking the oil, and don't fill it past the max level line
sutty86
PostPosted: 18:14 - 01 Apr 2015    Post subject: Reply with quote
Seller put new oil in before I bought did look high on the dip stick but its hard to read..
No max or min mark
Going to empty and put own oil in
Cheers
SQL
PostPosted: 19:09 - 01 Apr 2015    Post subject: Reply with quote
don't forget the filter behind the plastic cap, there is a little rubber o-ring behind the plug, make sure you use only a six sided socket on the plug as it IS made of brie
blurredman
PostPosted: 19:26 - 01 Apr 2015    Post subject: Reply with quote
I once emptied my airbox from the CX and it came out at 2 pints. Mind you, mine was more vapour particles turned to liquid. The vaccum on this bike goes downwards into the box from the rocker cover so there is no natural return of the vaccum through gravity when you let off the throttle..
Nevertheless, with that colour oil it looks like the bike's been overfilled, as others have mentioned.
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
The last post was made 11 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 59.11 Kb
