Metal polishing tips.
PostPosted: 12:34 - 31 Mar 2015    Post subject: Metal polishing tips. Reply with quote
I'm polishing up a piece of Aluminium, he has some scratches/pits I wany to remove.
Anyway I bought a polishing kit, some years back I never used, untill now. It has 3 mops and 3 bars. The Instructions basically say work from hardest to softest mop and use the corresponding bar with each mop.
I'm still working on the hardest setting as some of this stuff is taking an age to remove. I just wondered if anyone has any tips on how to speed it up/get a good finish? How much of the bar should I be using? I started using a fair bit but it seems like now there is more than enough on the wheel.
Dcwhite1984
PostPosted: 13:21 - 31 Mar 2015    Post subject: Reply with quote
I have no experience of this myself, however i have a copy of this months Ride magazine which gives a step by step guide into aluminum polishing.
If i remember when i get home i will try and put pics up. Smile
The trick to life is to not get too attached to it.........
WD Forte
PostPosted: 13:28 - 31 Mar 2015    Post subject: Reply with quote
On a related note we have been grinding some valves in recently and
my son noticed how good the paste was for polishing out deep scratches and crap from alloy.
Grinding paste followed by gentler abrasives may be worth considering
bikers smell of wee
Bikeless
PostPosted: 13:30 - 31 Mar 2015    Post subject: Reply with quote
Wet sand it till the most deepest scratches are removed then polish it.
mudcow007
PostPosted: 13:59 - 31 Mar 2015    Post subject: Reply with quote
i can get stuff polished in work if you need it done
stuff comes out super mega super duper polished
PostPosted: 14:09 - 31 Mar 2015    Post subject: Reply with quote
Thanks all will take the advice onboard.
Thanks for the offer I do appreciate it, but I want to do this myself. It's a piece from my project in the cycling forum and I want be able to say, I did that Very Happy
Suntan Sid
PostPosted: 14:17 - 31 Mar 2015    Post subject: Reply with quote
I'm no expert, I have had a go though.
For deep scratches I've worked my way up the scale of wet and dry finishing at 1200 before using mops and paste.
IME, overloading the mops is not the way to go all that happens is you tend to get a dirty finish.
Keep one mop with no polish whatsoever on it and only use it for a final polish, once you've gone through the range of pastes, with the other mops!
WD Forte
PostPosted: 14:26 - 31 Mar 2015    Post subject: Reply with quote
What are you driving the mops with?
bikers smell of wee
PostPosted: 22:04 - 31 Mar 2015    Post subject: Reply with quote
Mo powah! You need enough to get the part hot and to melt the polishing soap. If you can stall the mop without risking losing a digit - mo powah!
c_dug
PostPosted: 22:21 - 31 Mar 2015    Post subject: Reply with quote
Personally I start with a course grade wet and dry and work up to very fine emery or wet and dry before moving to metal polish (I use Carr, Day and Martin, but it's all much of a muchness). Also I only polish in straight lines. How course I start with depends on how bad what you're polishing is.
I have a decent supply between something like 80 wet and dry up to 4000 grade emery, don't mind popping a few sheets through your door if you like, just drop me a PM.
Actually I might even have a spare pneumatic polishing gun if you have a compressor.
mudcow007
PostPosted: 09:07 - 01 Apr 2015    Post subject: Reply with quote
this is what they use in my place
https://i25.photobucket.com/albums/c81/mudcow007/20130510_114516_zps684fdfae.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20130510_114511_zps8c0da41d.jpg
an use bars of red & white stuff on the mop
Dcwhite1984
PostPosted: 09:47 - 01 Apr 2015    Post subject: Reply with quote
Completely forgot about this until this morning, had a meeting which ran on a bit last night.
i did take pics this morning however i took them on my phone and not sure they came out too well, but here they are anyway:
https://i1056.photobucket.com/albums/t372/dcwhite1984/92DB59C1-9810-4235-9B2B-6BDC6A8CE468_zps2rxjurrw.jpg
https://i1056.photobucket.com/albums/t372/dcwhite1984/5BD7588D-4E35-431C-A7EC-7B18A0ACF68B_zpsiroou4kh.jpg
https://i1056.photobucket.com/albums/t372/dcwhite1984/9D8B1BEB-08C9-49A3-B4AB-D8AA4095D248_zpshadp0suz.jpg
And that was it, alternatively if these haven't come out too well PM me your address and ill post you the mag. Smile
Note - sorry about the rotation of the image, I'm a bit of a techno-phobe managed to rotate them online but didn't work when posting. As im at work haven't got time to sort it out.
UncleFester
PostPosted: 15:29 - 01 Apr 2015    Post subject: Reply with quote
Got 4 wheels like this.
https://i104.photobucket.com/albums/m172/unclebloodyfester/1596d99e.jpg
Worked from 100g to get down to the bottom of the worst marks then up through the grades to 2000g and then Megs NXT to get to this. Plenty of water to keep things clear - kitchen sink looked interesting for a few weekends.
https://i104.photobucket.com/albums/m172/unclebloodyfester/bd77d687.jpg
Took about 10 hours per wheel, all by hand - which was the challenge i set myself. If i was doing it again, i'd pay someone to do it or get a drill and set of mops etc.
2017 Z1000SX
WD Forte
PostPosted: 15:35 - 01 Apr 2015    Post subject: Reply with quote
Mo powah indeed
Pukka kit like Mudcows.
I tried using a 'kit' on a cordless drill.
Useless of course, elbow grease did better.
bikers smell of wee
PostPosted: 15:57 - 01 Apr 2015    Post subject: Reply with quote
I'm sorted for Wet and dry, Thanks polishing gun somes interesting, I do have a compressor, how big a one do you need? I'll be hopefully sorting it this weekend, If I'm struggling I'll let you know.
Thanks all for the help.
I'm using a fairly decent corded drill, the part gets warm but I wouldn't say hot. I have been using it with the part in a vice and moving the drill round it it. I might try either using another drill we have that has a pillar mount. Or put the drill I have been using in the vice and hold the part.
Anyway here is the part as was.
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/ch4AAOSwPhdU7cbf/$_57.JPG
I'll post pics of the Kit and how it looks now later.
ZRX61
Victor Meldrew
PostPosted: 19:17 - 01 Apr 2015    Post subject: Reply with quote
Using a drill is a good way to kill it, Drill bearings are designed for thrust loads, not side loads.
They're not one night stands, they're auditions.
PostPosted: 01:52 - 02 Apr 2015    Post subject: Reply with quote
https://img.photobucket.com/albums/v295/chris-red/D187EA3D-1AAD-45CE-A5A2-2E923A20DE56_zpsxrzvossa.jpg
https://img.photobucket.com/albums/v295/chris-red/E8209699-F841-4D02-8D62-A6B5776B0353_zps65tl8p1t.jpg
https://img.photobucket.com/albums/v295/chris-red/F265EFAF-0A3E-49D3-B7C6-23AC55164B33_zpsumpdlynd.jpg
The last post was made 11 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 10.14 - MySQL Queries: 13 - Page Size: 96.83 Kb
