Indicators & MOT's
Suntan Sid
PostPosted: 12:40 - 01 Apr 2015    Post subject: Indicators & MOT's Reply with quote
My project bike is a 1982 bike, AIUI bikes manufactured before 1986 do not require indicators.
I have no intention of fitting indicators, but the bike was originally fitted with them, so what do I need to do with the switch?
Do I need to blank it off, remove the switch, or just leave it?
PostPosted: 12:56 - 01 Apr 2015    Post subject: Reply with quote
I don't want to be that guy, but why not ask your friendly local MOT tester what he'll actually accept? It'll come down to his whim on the day.
UncleFester
PostPosted: 13:05 - 01 Apr 2015    Post subject: Reply with quote
AIUI .....
If it is fitted, then it must work.
If it is not fitted ( and is not legally req'd) then it cannot be tested as it is not present and is therefore not a fail.
As above though, why not ask the local MOT station.
2017 Z1000SX
dansp1
PostPosted: 13:43 - 01 Apr 2015    Post subject: Reply with quote
https://www.motinfo.gov.uk/htdocs/m1s01000501.htm
doesn't need them, easy enough to open the switch up and remove the indicator switch
Suntan Sid
PostPosted: 14:13 - 01 Apr 2015    Post subject: Reply with quote
You'd think so, but a ball bearing and other bits fell out, when I tried it! Laughing
WD Forte
PostPosted: 14:36 - 01 Apr 2015    Post subject: Reply with quote
Can't speak for other places but have taken similar aged bikes
( rats usually) to my MOT guy with indicators removed but switch intact
and got an MOT no bother.
Not even mentioned.
bikers smell of wee
Triton Thrasher
PostPosted: 16:09 - 01 Apr 2015    Post subject: Reply with quote
Saw the plastic tab bit off the switch.
Or write "Pillion Eject" on the switch. That's not a test item in the manual.
Rrrrrrrrrrrrrrrrrr
PostPosted: 16:50 - 01 Apr 2015    Post subject: Reply with quote
Cover the switch in gaffer tape. Remove after.
WD Forte
PostPosted: 16:51 - 01 Apr 2015    Post subject: Reply with quote
Quote from MOTUK
"If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or........."
I take this to mean if they are fitted they must work but don't have to be fitted on a pre 86 bike.
No switches mentioned so I'd leave them alone
Source
https://www.motuk.co.uk/mcmanual_150.htm
bikers smell of wee
dansp1
PostPosted: 16:56 - 01 Apr 2015    Post subject: Reply with quote
Not even mentioned.
There's the thing, it is one of the grey areas of MOT testing that is open to the testers interpretation, you may not get knocked back for it you may not.
PostPosted: 17:04 - 01 Apr 2015    Post subject: Reply with quote
My KTM and my SV have no indicators. Both passed MOT's.
My monkey bike had the switches taped over, passed.
Same with forks, can't fail for leaks if leaks aren't visible Whistle
dansp1
PostPosted: 17:15 - 01 Apr 2015    Post subject: Reply with quote
Could any of those bikes be covered by the "information" or "exemptions" on my link?
Or do you just have a tame tester?
PostPosted: 17:20 - 01 Apr 2015    Post subject: Reply with quote
Decent tester, however if it can't be checked, they can't fail.
You get an advisory for lights fitted but not tested.
An SV, 2000 reg, KTM, T reg, however exemptions for single seater off road bikes in this case, 06 plate monkey bike Thumbs Up
Monkeywrenche...
PostPosted: 09:37 - 02 Apr 2015    Post subject: Reply with quote
Well actually if an item should be tested but can't be (locked fuel cap so can't look at the rubber seal for example) then the whole test has to be abandoned.
If you have an advisory with "items not tested" specifically listed then your tester is running some risks with his testing authority, tell him he's better off just ignoring them. at least then he hasn't supplied signed evidence of his "mistakes" Very Happy
As far as the OPs question, the lamps themselves are the thing we're looking, for switches aren't important, unless the lamp is there but not a switch obviously, because that's definitely a fail.
PostPosted: 09:53 - 02 Apr 2015    Post subject: Reply with quote
Got source for that?
Lights should be tested but can't because they are covered up... you can't cancel that test purely because I cba to wire them up. Wink
dansp1
PostPosted: 10:36 - 02 Apr 2015    Post subject: Reply with quote
https://www.motinfo.gov.uk/htdocs/m1s01000101.htm
theres the get out for no lights at the top
https://www.motinfo.gov.uk/htdocs/m1s07000201.htm
https://www.motinfo.gov.uk/htdocs/m1i00000402.htm
those 2 combined are the reason for refusal to test
Monkeywrenche...
PostPosted: 10:42 - 02 Apr 2015    Post subject: Reply with quote
if the lights are covered,painted or masked then they shouldn't be tested, that's the difference...
as for the source, I'm a tester who runs a class 4 test station (although i have tested 1,2 and 5) and has access to the up to date manuals as well as a constant stream of revisions of opinion.
The rules governing "refusal to test" are in the "MOT testing guide" appendix 3 (part g) this is not the same as the inspection manual as it covers the system as a whole and not the test itself which are class specific. the refusal can and should happen at anytime although proper pre-checks will prevent starting a test on an untestable vehicle.
The last post was made 11 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 3.55 - MySQL Queries: 13 - Page Size: 91.8 Kb
