| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
 Posted: 16:39 - 30 Jan 2005 Post subject: Its fucked |
Hi,
Had been meaning to change the spark plugs for a while now. Got all the tools together that I needed and started...
Catalogue of fuck ups from the off:
Took long enough to figure out how to remove the tank (you think it could have been easier - Haynes manual is shit)
A screw holding one of the side panels had to be drilled out - it was so bloody tight it rounded so I had no other option.
Plug holes full of crap so got hoover to clean out most of it.
Got one of the plugs out - it was completely fucked, I'm surprised that it started at all!
Put in new plug - but I don't think that its' going down all the way.
Then attached HT lead and tried to start it - only firing on the other cylinder. Bugger.
Made sure HT lead was on properly - then it fell apart. That's right, the end of the HT lead was only just pushed together!!! Fuck me!
So basically I have two problems:
1) How can I make sure the plug is seated correctly.
2) Where (and how much?) can I get a set of HT leads for a 1998 ER-5.
I well pissed off. No bike and no money to take it to a garage
Any one got any ideas? ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..." |
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 17:28 - 30 Jan 2005 Post subject: |
You can buy any new replacement OEM parts for a Kawasaki from Z Power, but they don't list everything on their homepage and so contact them by e-mail with a full description of the bike ie year & model and explain to them what you need. They will contact you within 24 hours with a price for the repalcement.
www.z-power.co.uk |
| AcIdBuRnZ |
| Guest |
 Guest Brolly Dolly
 Posted: 17:45 - 30 Jan 2005 Post subject: |
You can buy replacement plug caps in various shapes .......
https://www.dirtbikestore.co.uk/acatalog/plugcap.JPG
Just cut the old one off and screw the new one into the end of the HT lead.
Of course, if your bike has those fancy combination leads and coils just ignore what I say  |
| stinkwheel |
 Posted: 20:43 - 30 Jan 2005 Post subject: |
Make sure there is no junk under where the plug is supposed to seat, a lump of blue-tak on the end of a screwdriver is useful for this. Now screw the plug in by tightening it 1/2turn, loosening 1/4 turn, tightening 1/2 turn, loosening 1/4 turn. This should clean any junk out of the threads and reseat any that are slightly bent.
Do not force it! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| AcIdBuRnZ |
| instigator |
 instigator Super Spammer
 Posted: 23:28 - 30 Jan 2005 Post subject: |
Mark - totally wish you'd told me about this before, could have saved you an age.
I've taken the tank off about 10-15 times now, and first time it took about 30 minutes, now, approximately one minute if you don't have to take the tank RIGHT off the bike, and 4 minutes if you do. The fuel tap is a right fidgety bastard to move around the frame and engine block. Its all in the technique relaly, ones you've got it, its easy.
And the right hand spark plug is a real bother to get out because of the coolant pipework. I wonder how the helll they managed to get away with planning that one????
My screws holding the mid fairings have almost rounded off as well (common fault) and believe it or not, I believe one of my plug caps is done for. Managed to bodge it on but its not very secure. The original ones are stupidly cheap and nasty, thinking of ordering myself some NGK ones instead.
Really pisses you off, doesnt it  |
| AcIdBuRnZ |
 Posted: 02:27 - 31 Jan 2005 Post subject: |
Never thought you'd have had much time to play with the mechanics of the bike Greg - I've had mine almost a year!
Never had a reason to remove tank until now.
I removed the tank and turned it 90 degrees to rest across the bike - that how you do it?
Anyway, needing new HT leads. Can't do nothing until they arrive.
Pissed off - I hate leaving a job unfinished  ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
| instigator |
 Posted: 10:18 - 31 Jan 2005 Post subject: |
| AcIdBuRnZ wrote: | I removed the tank and turned it 90 degrees to rest across the bike - that how you do it? |
Well, thats the way I do it now, for jobs like adjusting the head bearings if they're notchy (cheers stinkwheel) but firstly, when putting in the restrictors, the tank has to come right off. You just take off two pipes on the fuel tap, negotiate the fuel tap around the frame and voila, its off. Everyone says its not easy to do at first, its a right c*nt of a job.
If you hate leaving jobs unfinished, try this one for size. I drained the oil on my bike, put drain screw back on and started filling it up again. Filled it up with 2 bottles of 1l silkolene and realised I didnt have enough (8 mile trip to get some more, the NEXT day)
Then, when I filled it up with the single bottle, I realised I didn't change the oil filter.
BUGGER!!!!!
No chance I was going to take the oil out and waste more money/get contaminants in it. |
| AcIdBuRnZ |
| Scotsman37 |
 Posted: 15:14 - 31 Jan 2005 Post subject: |
Would it not move even with a torque/socket wrench?
It must have been over tightened without the use of a torque wrench.  |
| kasandrich |
 kasandrich Trackday Trickster
| AcIdBuRnZ |
| kasandrich |
 Posted: 15:59 - 31 Jan 2005 Post subject: |
^^^^or a sharp'sh screwdriver, and tap a notch into the rolled edge, then try and tap it around with the hamer and screwdriver.  ____________________ Richard
CBR1000FM |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 17:13 - 01 Feb 2005 Post subject: |
| bish777 |
 bish777 World Chat Champion
 Posted: 17:18 - 01 Feb 2005 Post subject: Re: Its fucked |
| AcIdBuRnZ wrote: | Hi,
May have been a little premature buying new leads.....
You can snip half a centimetre off and screw the cap back on.
Dont be too scared when putting the plug in, grab the socket handle close to the ratchet end and tighten til it wont move. Then give it a quarter turn using the full length of the handle. That should seat it. Bear in mind you have to crush the washer on a new plug. Dont be too timid! |
| Scotsman37 |
| stinkwheel |
| AcIdBuRnZ |
| stinkwheel |
| Kickstart |
 Kickstart The Oracle
| AcIdBuRnZ |
| map |
 map Mr Calendar
| stinkwheel |
| map |
 map Mr Calendar
 Posted: 13:11 - 03 Feb 2005 Post subject: Re: Its fucked |
The last post was made 21 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
