zx6r holding back
chappy
PostPosted: 14:15 - 01 Apr 2015    Post subject: zx6r holding back Reply with quote
Hi there my zx6r g2 needed to go in for a new chain and sproket change so i asked the man to sync carbs why it in there 2 . I took the standed can of and put my new pipe works slip on can on day before so he could tune carbs to this . I Tested it first seam to run sweet ..
So bike machanic calls said bike ready to be picked up . I went along to grab it and he said the carbs did not need doin they already set up for the exhaust old owner could of had it done before sale and put standed can back on . But he did say he turnd the idel up a bit .
So bike running smooth no knocks from the chain smooth in gears but just aint got that killer pull it used to have in high revs it seams bit slow picking up speed and i need to knock it down a gear to 5th on motoway ridding as 6 dont pick up speed fast .
The machanic said the idel was only thing touched on bike so could this be problem . Unless he aint tightend up the carb rubbers proply .
By way he builds race bikes at his shop so always used him no problems before. Any help wot to look for please guys .. ??
DrSnoosnoo
PostPosted: 14:27 - 01 Apr 2015    Post subject: Reply with quote
Is the airbox on properly?
I think yours is ram air, and if it's like the ZZR6E the tubes from the ram air can be a bit of a git to get into the airbox, so there could be an issue there.
chappy
PostPosted: 14:55 - 01 Apr 2015    Post subject: Reply with quote
Thanks yeah its ram air vershion ..Gona get tank off later today or friday and stip air box and check tubes and carb inlets rubber because i sware i could hear a air noise under tank high revs . .
But when googleing somone mentioned the idle speed bein touched in a old post and he did touch mine so fort problem lies there as was nerver a problem till he touched it .
DrSnoosnoo
PostPosted: 15:09 - 01 Apr 2015    Post subject: Reply with quote
In my experience, adjusting my idle speed does just that and affects nothing else.
PostPosted: 17:48 - 01 Apr 2015    Post subject: Reply with quote
The idle speed normally (and sure it's the case on this model) just sets the minimum opening where the throttle cable actuates. It makes no difference once you have opened the throttle.
chappy
PostPosted: 18:34 - 01 Apr 2015    Post subject: Reply with quote
Ok thanks for help so i put it down to him bolting the ram air / carbs wrong . I give that ago . Also try the old can back on there . Thanks for help
misscrabstick
PostPosted: 19:30 - 01 Apr 2015    Post subject: Reply with quote
Mine hated an aftermarket can, it ran like a pile of crap, if your going with the sporty can accept that you will also need proper rejetting and dyno time/dynojet kit.
I put the standard can back on just could not be bothered with it all.
davebike
PostPosted: 07:48 - 02 Apr 2015    Post subject: Reply with quote
And there is you problem next stop Dyno runs to sort fuelling !!
Carb balance is not a cure for wrong jetting
Dave
NC750Xdct + others at work !
davebike1@gmail.com
The last post was made 11 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 5.24 - MySQL Queries: 13 - Page Size: 56.8 Kb
