Rad cap fun and games
jjdugen
PostPosted: 10:29 - 02 Apr 2015    Post subject: Rad cap fun and games Reply with quote
Just had a 'blade in, a '97 carby. Owner told me it was pissing coolant once hot.
Sure enough, as soon as it got up to temp, water started dripping from the bottom of the fairing. Took off cap, had a quick check, looked fine.
Filled it up again, giving it a good session of burping to clear any air pockets. Ran it up for a while, did a sniff test, no head-gasket problems.
Replaced cap, ran it up until the fan cycled a few times, all was well.
Let it cool a bit, took off cap to top up, replaced cap, ran it up, water pissing out again.
Longish story cut short. The caps sealing rubber had a minute split. put the cap on one way, it sealed, put it on the other way round, it pissed coolant. New cap fitted, all is well. Never seen that before!
devojunior
PostPosted: 11:59 - 02 Apr 2015    Post subject: Reply with quote
surely with cap off it shouldnt over spill unless it was just from the return pipe yes it will steam and gurgle abit but not over spill as the circuit is only circulating unless air is entering the cooling system and forcing coolant up and out .
jjdugen
PostPosted: 12:02 - 02 Apr 2015    Post subject: Reply with quote
RTFPP read the fucking post properly!
Kris
PostPosted: 12:11 - 02 Apr 2015    Post subject: Reply with quote
Yea that's an odd one, albeit a nice easy fix.
I once had brake lights permanently on. Only after taking the whole rear end off the bike and looking for shorts did I actually look at the stop/tail bulb. Both filaments were touching... Doh!
www.prisonplanet.com
The last post was made 11 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 39.78 Kb
