Another MOT light question
Northern Monkey
PostPosted: 10:57 - 02 Apr 2015    Post subject: Another MOT light question Reply with quote
My royal enfield is due an MOT.
Both of the small position light bulbs above the headlight have blown.
The sidelight is inside the headlight, this works correctly
The headlight also works correctly, both main and dipped beam
https://cdn4.canadamotoguide.com/wp-content/uploads/2010/07/headlight.png
Is this a reason for failure?
Monkeywrenche...
PostPosted: 11:23 - 02 Apr 2015    Post subject: Reply with quote
You just need 1 position lamp(if its in the middle) a dip beam with the right pattern and a main beam, the additional sidelights don't need to be tested if not working.
Sometimes people refer to "if its fitted it has to work", this is a hangover from the days they used to write certs by hand and make up failures they were sure were right , there are obligatory items and anything else is untested.
Triton Thrasher
PostPosted: 11:38 - 02 Apr 2015    Post subject: Reply with quote
MoT or not- Why don't you want to fix the lights?
Rrrrrrrrrrrrrrrrrr
PostPosted: 12:18 - 02 Apr 2015    Post subject: Reply with quote
The strict letter of the manual say position lamps are not obligatory if you have a headlamp, but that any position lamp, whether obligatory or not, is a fail if it "does not illuminate immediately it is switched on".
My tester wouldn't bother, yours may have a different view.
LED bulbs, Y U NO?
cheeseman
PostPosted: 12:38 - 02 Apr 2015    Post subject: Re: Another MOT light question Reply with quote
Looks like it should be a dead easy fix - don't you just need a cross-head screwdriver there to get in to the bulb?
XJ600S->Sprint ST 955i * ; Now ST1100 + W650
Northern Monkey
PostPosted: 14:50 - 02 Apr 2015    Post subject: Reply with quote
It is an easy fix, but I don't have any spare bulbs, and I was going to take it to the MOT station this afternoon
PostPosted: 15:01 - 02 Apr 2015    Post subject: Reply with quote
I'd not worry and drop a dabble of tape on it.
If they fail you, contest it Wink
Unsure why people worry, just simply tape them all, you don't need a retest.
The last post was made 11 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 51.81 Kb
