Should I practice mod 1 manoeuvres on a 125?
daifuco
PostPosted: 11:28 - 03 Apr 2015    Post subject: Should I practice mod 1 manoeuvres on a 125? Reply with quote
So as some of you know I failed my mod 1 (A license). I really didnt practice the U turn that much for a number of reasons... end then:
I got too nervous.
I didnt play well with clutch/gas
I focused on the line rather than on the exit...
Foot down!!! Mr. Green
Ok I have been on a 600cc before . I know the handling is much different. And I know that the clutch and gas feels different.
But I am considering to practice a lot on the 125 so I automatically do the right things and hopefully my brain just has to work a little bit compensating for the 600.
One of the good motorcycle training business around offers just a few hours of training and mod 1 on the same day (late afternoon) for a reasonable price, so I could use that time to get used to the big bike. (and they have a MT-07 so if Im lucky I could try one of the possible candidates once I pass)
My instructor said it was NOT a good idea to practice on the 125, but now I know they are awful. So I'd better ask BCF!. Should I practice on the 125?
It is mostly the figure of 8 and the u turn what I will practice. Leaving the others for the hours before MOD1
PostPosted: 12:38 - 03 Apr 2015    Post subject: Reply with quote
They're both motorcycles, physics doesn't magically change on a bigger bike. Not that an MT-07 is that much bigger than a 125 anyway.
Just practice with lots of revs and slipping the clutch.
NJD
PostPosted: 12:49 - 03 Apr 2015    Post subject: Re: Should I practice mod 1 manoeuvres on a 125? Reply with quote
£9-10 set of plastic cones from my local argos, 1-2 hours of cone bashing (with tighter measurements than the actual test) at the back of a supermarket car park and I aced the slow manoeuvre without any faults.
Didn't practice the high speed manoeuvres and failed on them no surprise.
I'd say that you could let the clutch out on a 125cc while doing a U-Turn in a tight space and bring it back in control a whole lot quicker than you could on something with more torque, if you don't feel you can nail the manoeuvres on a bigger bike then practice on something with a smaller engine and build your way up.
Acemastr
PostPosted: 17:08 - 03 Apr 2015    Post subject: Reply with quote
slip slip slip slip slip the clutch and look where you want to end up, more revs = more balance so don't worry if it's screaming along and keep the clutch where it is if you're going slow enough. I can actually just about do a decent U turn on the R6 now, steering lock is horrific but loads of revs and clutch slip makes it easier
2016 Toyota Tacoma Limited
daifuco
PostPosted: 17:28 - 03 Apr 2015    Post subject: Reply with quote
The problem is that I am too used to the cbf125 and its soft clutch that you dont need to use because the engine is so mild you control it ok with the gas.
Once I went on the Hornet I felt afraid of using the clutch and throttle, when you are nervous it is difficult to keep cool.
Teflon-Mike
tl;dr
PostPosted: 17:35 - 03 Apr 2015    Post subject: Reply with quote
You only say that to annoy me....
Ahrgggggggg.. no.. no it doesn't!
winz
PostPosted: 17:53 - 03 Apr 2015    Post subject: Reply with quote
Just keep your left hand steady when slipping. You can rev the tits off it, but you won't go anywhere if the clutch is in.
If you use a little back brake and you will feel quite planted and stable. Smoothness is key.
Acemastr
PostPosted: 18:03 - 03 Apr 2015    Post subject: Reply with quote
Mike, I was under the impression that the turning of the engine actually provides centrifugal force, thus balancing the bike more.
Worked fine for me so far!
alex965
PostPosted: 18:18 - 03 Apr 2015    Post subject: Reply with quote
I saw a guy doing a DAS who failed his mod 1 by locking up the brakes during the emergency stop on the 650 he was using. The instructors couldn't understand why he'd messed it up, he had apparently been really switched on throughout the course and done really well in the mock mod 1 tests.
He later told everyone that he'd taken his Varadero 125 out on a 300 mile road trip the day before and had been practising emergency stops throughout. Evidently, he didn't take into account the fact that the brakes on a 650 behave differently to his 125.
Imho practice on a 125 is good, when I transitioned to a bigger bike, I found that the years I has spent on 125s meant that I picked up riding a bigger bike really quickly. So it is a translatable skill set.
It only seems to bite people on the arse when they forget that they need to take into account the differences in handling and performance that bigger bikes have.
Passed A2 licence 19th Dec '14.
Teflon-Mike
tl;dr
PostPosted: 18:36 - 03 Apr 2015    Post subject: Reply with quote
Acemastr wrote:
Mike, I was under the impression that the turning of the engine actually provides centrifugal force, thus balancing the bike more. Worked fine for me so far!
Yup, and the wheels act like gyroscopes.... Rolling Eyes
Its negligible to non existant... you get stability SIMPLY from moving.. at slow speeds you have little stability, ad slipping the clutch to try and 'under-drive' the bike slower than its stall speed, is actually robbing you of the stability that the force you are not transmitting to the back wheel might offer, as well as the momentum actually letting it run at the speed it can clutch out could give.The diamond cutters of motorcycle 'control' are trials riders and stunters; we DON'T 'slip and drag' to under-drive the stall speed; IF we need to make the bike go that slow, we down gear, so we CAN go that slow, under 'drive', and not have to jiggle three controls, in the motorcycling equivalent of patting your own head and rubbing your tummy, that is significantly JUST to satisfy a test examiner of your 'control dexterity'..
Twenty years ago, it was a cheap trick, to get frustrated newbies doing U-Turns on DAS bikes, it's actually so engrained now, as DAs has become the defacto route to big bikes, that ofte no-one knows any other way, to slow-speed manoeuvre, ad almost 'lore' the best way to effect 'fine slow speed control'.. in actual fact its an abandonment of control.. if you were in control you should be able to do it above stall speed, making it utterly un-necessary. If you cant? Then man-handle it, 'in full control' under leg-power to go that slow, with two feet adding support so you DON'T have to balance the damn thing. Don't fucking drag and slip!
...Except to make an examiner holding your pass cert in his hand happy!.... where all you need do is touch a lever enough to make the brake lamp stay on, and slip enough revs occasionally to let him believe you are patting your head and rubbing your tummy.
daifuco
PostPosted: 19:35 - 03 Apr 2015    Post subject: Reply with quote
So recaping:
Practice on the 125 as much as possible
Spend some time on the test bike before the test.
Rev and slip the clutch... because I have to do it.
NJD
PostPosted: 19:39 - 03 Apr 2015    Post subject: Reply with quote
This to get you used to the basics of how a motorbike feels when doing a U-Turn or going around a set of cones etc.
Would be helpful Rolling Eyes Laughing
This to get you used to what the actual bike you'll be doing the test on feels like now you've learnt how to do the manoeuvre on a more forgiving bike.
As for point #3, you'll learn how to control the bike in each manoeuvre when practising.
daifuco
PostPosted: 20:02 - 03 Apr 2015    Post subject: Reply with quote
The thing is that a 4 hours practice and then MOD1 is a LOT cheaper than a full day and then MOD1 next day. Hopefully 4 hours would be enough.
NJD
PostPosted: 20:09 - 03 Apr 2015    Post subject: Reply with quote
I attempted the Module 1 on my own 125cc of course the advantage being I know what it feels like since I'm on it all the time.
Went down to my local empty supermarket car park, purchased a set of cones.. measured out the distances for the cones and practised the manoeuvres for 1-2 hours, by that time I could tight U-Turn and go around the figure of 8 until I got dizzy or bored, this was one day before the test (only done basic u-turns and slow controls on and off before this point) and then when I went for the actual test I had 0 faults on all the slow manoeuvres (darn those high speed fails Embarassed ).
Depends on your ability but.. I'd say that four hours is plenty of time (providing you practise on your 125 before) to get used to how to control the bike.. plus the advantage with the way you attempt to do it is that it's all fresh in the mind as you have been doing it practically a few hours ago.
PostPosted: 22:02 - 03 Apr 2015    Post subject: Reply with quote
daifuco wrote:
So recaping:
And don't make excuses for putting it off or convince yourself that it's hard. You only need to do it right once during the test. Just sack up and get it done, you're not going to get a license during a training session.
Barnoe
PostPosted: 00:18 - 04 Apr 2015    Post subject: Reply with quote
The problem most learners have with tight control is the fear of leaning the bike.
Keeping the bike as upright as possible is a skill in itself when doing sharp turns, but as a learner you will turn a lot easier if you use forward momentum and lean a little while looking where you want to end up.
If you need to slow the bike pull the clutch in, rolling the throttle off quickly during a sharp turn will make the bike unstabe.... you could end up putting a foot down :/
like everything in life... practice makes perfect.
If you ride correctly, the engine size and weight makes no difference..... if you ride like an idiot, smaller bikes are more forgiving to errors Wink
You know you are old when you're told to slow down by your doctor and not the police.
talkToTheHat
PostPosted: 07:03 - 04 Apr 2015    Post subject: Reply with quote
When I was training for my mod 1, the site the training school used had some extra obstacles from the forklift people that also used the area, so the turn radius for the approach to the fast manoeuvres was very tight. Not a problem on the das bandits, but to achieve 50kph I learned how to get a pseudo-cruiser to skim pegs without catching my boot. Much noise made about the difference between needing to torture my 125 and the effortlessness of a 600, as 90kph through the speed trap was technically not a fault but makes the examiners really twitchy.
Some of the days course riders had their own 125s and were encouraged to practice on them, but the differences in acceleration and braking performance were noted.
A 125 is easy to catch if you topple at walking pace and is easier to pick up than a big bike, so work on your low speed manoeuvres, see how how tight you can get the bike turning and get comfortable with a bit of lean during low speed agility tests. You won't have anywhere near as much to think about getting on a big bike then.
When I did my cbt the year before, it had been ten years since I had been on a motorcycle and I had not been on a push bike for maybe 5 years. I had asked to split my CBT into sessions no longer than 2 hours due to my epic lack of health, and after the first session, was very pissed off with myself for having lost skills i knew I used to have. I was encouraged to try slaloms and figure 8s on a pushbike, so I sorted out the random junk bike living in the shed, cut some tennis balls in half, and after a few short sessions I had my balance and confidence back, and it transfered directly into my ability to ride a ybr.
You can learn useful skills with any two-wheeler. You won't get clutch control on a pushbike and a big bike needs a fine touch where a 125 needs wide open throttle, and in the case of my gz, a very firm braking hand, but where there are similarities, use them.
Bandit. does. everything.
daifuco
PostPosted: 00:10 - 05 Apr 2015    Post subject: Reply with quote
To be honest I have noticed that I am very afraid of u-turning even on my cbf125 so for once I think the system has worked catching a fault that needs to be addressed.
Taught2BCauti...
PostPosted: 08:29 - 05 Apr 2015    Post subject: Reply with quote
Unfortunately, it's one of the hoops you have to jump through to get that ticket - but it's a manoeuvre that I would never attempt in real life. I would prefer to continue ahead to the next roundabout, or go around the block, than do a 'U' turn on the road.
If you can find an empty car park (Aldi or Lidl near closing time) and start off practising going around in ever-decreasing circles, in both directions, getting slower and tighter - this will help you with the slow riding, slalom, figure of 8 and the dreaded 'U' turn.
If you can master these manoeuvres on a 125, a bigger bike will make them even easier.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Taught2BCauti...
PostPosted: 09:41 - 05 Apr 2015    Post subject: Reply with quote
I'm actually quite good at 'U' turns - and weaving in and out of cones - it's just my personal preference not to do them myself on the road.
Watching other people do them badly on YouTube is enough for me Smile
Teflon-Mike
tl;dr
PostPosted: 15:02 - 05 Apr 2015    Post subject: Reply with quote
There are times it can be useful.... not sure 'essential', but certainly 'useful'.
I was up the Gt Orme in Landudno, last summer, looking for the ancient copper mines; coming in the 'wrong' way from town, of course I rode past the sign looking for the place & only my daughter on the back slapping me between the shoulder-blades made me look round to spot it!
Narrow, less than 2m wide, gravel strewn lane, on a bludy big hill.. nearest T-Junction to do a U-ie, half a mile up, and not much nicer, next roundabout three miles up, back at the bottom of the hill, in town... WHAT do you do?
Had a similar one, again with daughter on the bunny, going to a country park; mile down a narrow, gravel strewn, leafy lane, to find the pike gate across the car-park entrance at the bottom.. NO-WHERE to go BUT back the way we came... WHAT do you do?
U-Turns can be useful, and if you have the confidence to do one, possibly one of the better ways about it....
If not? Well, probably the most common answer is to do a 3-point... and why not?
Well, paddling is something you do at the beach, NOT on a motorbike... And far too many folk are LOATHE to get off the bike.
Paddling the thing backwards, you have one leg on the floor at a time propping you up, AND you are trying to use it to push the bike at the same time, AND look over your shoulder, its NOT stable and its not giving you good control, and you are as, if not more, likely to drop the buddy thing when you're one pushing propping foot slips on that shitty gravel or leaves, as if you tried riding through it in a powered U-Turn, feet-up!
GET OFF, man handle the bike round to where you want it pointing... get back on, ride off! Simples!
Its safe, its stable, its neat, it gives you THE most balance, THE best field of vision, and THE most control you can have to point the bike where you need it pointing.
And THIS is why the man-handling exercises are on the Mod 1! DSA don't REALLY give a shit whether you can get your own bike in and out of your garage on your own drive! Why should they? But, it is one of the 'better' ways to SAFELY manoeuvre a motorcycle, in 'full control' in a tight spot, at speeds slower than stall-speed in first, where the surface is 'iffy', and THAT is why its on the test.
And unlike 'Drag & effing Slip' man-handling IS a technique that you can and should use regularly; that IS very useful, and a bit of 'discipline' that used as routine, rather than 'paddling', can save a LOT of hassle and embarrassment!
Much under-utilised bit of technique, to my mind, but still.
(Yes, CAN be a bit embarrassing to ask a pillion to clamber off so you can do it.. but a DAMN site less embarrassing than apologising as you try and lift the bike off their leg, after mis-footing trying to paddle it!)
talkToTheHat
PostPosted: 18:08 - 05 Apr 2015    Post subject: Reply with quote
Practice those U-turns. It's cheaper than failing a mod 1 on a hired bike. You might find some bikes have better steering lock than others, so technique for a bike with lots of lock won't work for a barge.
If the turning circle is marginal, start the U-turn about 2 feet from the kerb/white line as if you had pulled up in a slightly lazy manner. Turn towards the kerb then turn hard away from the kerb. This way you can be at or near full lock as you pass closest to the kerb.
Given how countersteering works, done at with enthusiasm, the above can feel like one motion. Importantly, leave yourself room for the front wheel to turn left to initiate a right turn.
daifuco
PostPosted: 00:32 - 06 Apr 2015    Post subject: Reply with quote
Tomorrow I am going to uturn the shit out of my cbf (first full day off since the drama-failure last week) I think the best is trying on different roads with different widths.
Can I damage the bike by using the clutch too often? I have heard you can't but I have heard a lot of bullshit lately (and not necessarily in BCF)
The last post was made 11 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 144.88 Kb
