| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 15:14 - 03 Apr 2015 Post subject: |
I remember having this problem years ago, and resolved it by removing all of the balls, and using a blob of Blu-Tack on the top and bottom races.
Put the parts together, then separate them. The Blu-Tack will be squashed, and the thinner piece is where the smaller ball bearings go, thicker piece is where the larger ones go. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Taught2BCauti... |
 Posted: 18:32 - 03 Apr 2015 Post subject: |
Can't remember what (or who's) bike it was - it was a long time ago - but definitely not a KMX.
Someone had stripped the yoke down and removed all the ball bearings, before realising there were two different sizes.
I used two balls of Blu-Tack, just a bit bigger that the larger balls - to work out whether the smaller balls went on the top or the bottom.
I suppose you could just go by trial-and-error - if you get it wrong, there will be some lateral movement at the top or bottom. ____________________ Honda Varadero XL125(V8)
| Taught2BCauti... |
 Posted: 13:02 - 04 Apr 2015 Post subject: |
If the ball bearings go back the right way round, they will make equal contact with their respective races - if they go back wrong, only the larger ball bearings will make contact with the race, the smaller ones will be loose and the yoke won't tighten up correctly. ____________________ Honda Varadero XL125(V8)
The last post was made 10 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
