How to stick mirrors on... Heavy duty blu tack?
BillyJ
PostPosted: 10:40 - 05 Apr 2015    Post subject: How to stick mirrors on... Heavy duty blu tack? Reply with quote
My ducati mirrors had lost half their reflective backing so I got an acrylic mirror sheet to laser cut some new ones.
The old glass mirrors were stuck in using this really sticky, stretchy, black stuff and I would use it again if I knew what it was called. Does anyone know what it's called or how would you stick a mirror back into it's holder which has only two small flat ledges at either side of the holder for mounting the glass?
I imagine the black stuff was also a good shock absorber to reduce vibration so I want whatever substitute I use to do the same.
EDIT:
It was like this:
https://www.amazon.co.uk/Black-black-strength-adhesive-photographers/dp/B0051BT40K/ref=sr_1_1?s=electronics&ie=UTF8&qid=1428230584&sr=1-1&keywords=black+tac
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
PostPosted: 11:08 - 05 Apr 2015    Post subject: Reply with quote
3m VHB double sided foam tape would do the trick.
Just don't expect to get them off again once fitted. Ever. make sure they are exactly where and how you want them before pressing them on.
I have three, 1" long pieces of this sticking a mast foot to the bottom of my canoe, you can lift the whole 30kg boat up off the ground by it.
BillyJ
PostPosted: 11:11 - 05 Apr 2015    Post subject: Reply with quote
Perfect, thanks Thumbs Up
andys675
PostPosted: 11:18 - 05 Apr 2015    Post subject: Reply with quote
it's probably their 3 bond engine sealant, but it's about £20 a tube
The last post was made 10 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 40.69 Kb
