| sutty86 |
 sutty86 Trackday Trickster
 Posted: 10:57 - 05 Apr 2015 Post subject: lack of acceleration |
OK I have a derbi Terra 125 yes I know 125 arnt the fastest things but comparing it to my old ybr this thing sucks at setting off.
Just tried servicing it ,fresh oil,air filter,spark plug, couldn't get access to oil filter.
To see if it would fix my problems.
It didn't,
Its dangerously slow setting off like it doesn't start moving until 5000 revs upwards and when I red line it to test it 10000+ it hits 20mph on the speed which in realife is about 15, bump into second ,same again takes hella lot of revs to get moving.
Whilst removing the old spark plug its a pain to get to, the old plug was filthy
https://i.imgur.com/VIHuDQa.jpghttps://i.imgur.com/Z4N5OiP.jpg
https://i.imgur.com/YqIagq6.jpg
Not sure what's happened to cause the white Gunk
On starting the engine I normally have to hold the throttle down to start the engine it starts cold just over 2000rpm then after 2 mins settles around 1700...
Was it could be the clutch slipping , and was told to put it into first and give no revs which it give a tiny little lunge nothing as dramatic as ybr and cut out ...
Air filter is new,but was residue of oil and water which I thoroughly cleaned.
Battery is good motobatt sitting at 12.8v
New spark plug is iridium , no difference to before with normal spark plug...
I did find some metal in oil change like I said I couldn't get the filter out so can't properly investigate https://i.imgur.com/nZvvAzD.jpg
Anyone help, I think the carb is a balls to get out but have put small quantity of FedEx,fresh petrol to try clean it out,allegedly was cleaned out a few weeks back... |
| iooi |
 iooi Super Spammer
 Posted: 11:09 - 05 Apr 2015 Post subject: |
Possible knackered head gasket. Or the gunk from airbox has been dripping down.
TBH. Get the head stripped off and have a good look at the piston etc. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Ariel Badger |
 Ariel Badger Super Spammer
| sutty86 |
| iooi |
 iooi Super Spammer
 Posted: 15:31 - 05 Apr 2015 Post subject: |
Was that plug really loose?
As the crap is well down the threads....
Ariel Badger.
Took me a few long looks to work out what it was. A view of the top of the plug....
At 1st I thought it the was working end of the plug with no electrode..... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| sutty86 |
| sutty86 |
 Posted: 11:22 - 06 Apr 2015 Post subject: |
Just put bike on some stand I bought and chain is I think loose,
Just want to run it past you guys first
https://youtu.be/Zbnb3xI3HmA[/url] |
| sutty86 |
| prawny1 |
 prawny1 World Chat Champion
The last post was made 10 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
