Why do 2 strokes have lots less engine braking than 4stroke?
NSR125-Kid-UK
Attention Whore
PostPosted: 21:38 - 30 Jan 2005    Post subject: Why do 2 strokes have lots less engine braking than 4stroke? Reply with quote
Just something I've been wondering for a while, I've never really found out why.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Dom_
Points Mean Prizes
PostPosted: 21:41 - 30 Jan 2005    Post subject: Reply with quote
Because 2 strokes fire twice as often, helping to spin the engine.
I'm crap at explaining, but it's not hard if you really think about it.
Silver
PostPosted: 21:42 - 30 Jan 2005    Post subject: Reply with quote
You mean NO engine braking? I nearly bloody crashed into a roundabout when I rode my brother's old RS250! Embarassed
Errr, don't know anyway, aside from the obvious "difference in engine design" answer.
NSR125-Kid-UK
Attention Whore
Well there's enough engine braking on my NSR to lock the rear up shifting from second to first Smile ?
Silver
PostPosted: 21:43 - 30 Jan 2005    Post subject: Reply with quote
That's not engine braking!
NSR125-Kid-UK
Attention Whore
PostPosted: 21:45 - 30 Jan 2005    Post subject: Reply with quote
What is it then?
Frost
PostPosted: 21:48 - 30 Jan 2005    Post subject: Reply with quote
One of the main reasons it because people compair them to a 4 stroke of similar power, which is typically double the capacity. and allthough it gives the same power as the two stroke, it gives more than double the engine braking.
Stroke length and compression would also play a part.
Silver
PostPosted: 21:50 - 30 Jan 2005    Post subject: Reply with quote
Briefly:
That's you changing down too early and the back wheel turning at a different speed to the engine.
Engine braking is when you back off the throttle and the bike (and cars too) slow down (fairly quickly). Two strokes keep rolling.
NSR125-Kid-UK
Attention Whore
PostPosted: 21:52 - 30 Jan 2005    Post subject: Reply with quote
Ah okay, nope the NSR just keeps rolling. Thumbs Up Smile
BLOFLY 636
PostPosted: 22:01 - 30 Jan 2005    Post subject: Reply with quote
I think it is to do with the size of the cylinder and compression ratio for example a 1000cc V-Twin has a lot of engine braking because it has 2 500cc cylinders and a high compression ratio where as a small 125 or 250 has 1 or 2 125cc cylinders with a relatively smaller compression ratio
Those bloody footpegs......they ought to do away with em!
Ric
PostPosted: 22:08 - 30 Jan 2005    Post subject: Reply with quote
lol @ no engine breaking on the 250 silver
feels well odd when its just not there!! just not right
it has something to do with the 2 stroke moving parts (ie doesnt have to move so many things in the engine) the 4stroke has weighty bits that move when the engine turns
or so i think i herd
Dom_
Points Mean Prizes
PostPosted: 22:11 - 30 Jan 2005    Post subject: Reply with quote
I would have thought it's mainly to do with the fact that the piston is being fired on every other stroke, which helps move the bike. Whereas on a 4t you got to have 4 strokes before each spark, so its twice as good at slowing down.
NSR125-Kid-UK
Attention Whore
PostPosted: 22:14 - 30 Jan 2005    Post subject: Reply with quote
MEh.
All that power on a four stroke engine that goes to waste turning the cams and opening/closing valves Shocked .
I read somewhere that a huge chunk of engine power goes to running the engine, and a lot's taken out of the power before going to the rear wheel - of course, I'm sure you probably know all this, but the idea of such a wasteful inefficient engine gives me pause Confused.
cagiva gezzer
PostPosted: 23:50 - 30 Jan 2005    Post subject: Reply with quote
No exhaust stroke, and where the exhaust stroke should be is a power stroke, wel almost.
mrchips
PostPosted: 00:19 - 31 Jan 2005    Post subject: Reply with quote
Riding even a 4 stroke 125 is an amazing difference from a 2 stroke as you can't coast it to the same extent ie coming up to a roundabout or something.
Northern Irish? www.nibikers.com
PostPosted: 00:34 - 31 Jan 2005    Post subject: Reply with quote
A 4 stroke has a compression stroke where it is compressing the full volume of the cylinder by about 10 to 1.
With a 2 stroke a load of ports are open so it is only compressing it by 6~7 to 1.
loply
PostPosted: 01:03 - 31 Jan 2005    Post subject: Reply with quote
four stroke has 3 nice big reciprications of the piston all without any power being produced what so ever!
two stroke gets new power produced every second recprication.
dont know how much this contributes to engine braking since the throttle is closed anyway so the power strokes wont be making much power anyway.
Yamaha SZR660 Caution to the wind, the throttle pinned!
kasandrich
PostPosted: 12:31 - 31 Jan 2005    Post subject: Reply with quote
The four stroke may do two revolutions per power stroke (per cylinder of course), but when it does a compression stroke it is a full length compression stroke, whereas a 2 stroke has ports that are open, so only gets half a compression stroke.
Its a little more complex than that, as the 2 stroke cylinder is charged, by crankcase compression, and when the throttles shut, the charge into the crankcase is reduced, therefore when its compressed very little happens. (If you compress a vaccum, you may only get atmospheric pressure).
Richard
CBR1000FM
sickpup
Old Timer
PostPosted: 12:51 - 31 Jan 2005    Post subject: Reply with quote
Internal friction caused by the cams and cam chain, generator etc.
as well as weight of internal parts being accelerated and de-celerted are higher than a four-stroke.
Note. Engine braking happens with a closed throttle although friction is always there. Theres an interesting piece on it in one of John Robinsons books.
palmer
Fiddled Kiddy
PostPosted: 18:46 - 31 Jan 2005    Post subject: Reply with quote
my ar50 2t has engine braking, it back fires too Thumbs Up
think its on its last legs, i thrashed the hell out of it yesterday, started it up today and a VERY load pop came out of the exhaust :s
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 4.69 - MySQL Queries: 13 - Page Size: 106.45 Kb
