'97 blade water pump seal change.
PostPosted: 22:07 - 10 Apr 2015    Post subject: '97 blade water pump seal change. Reply with quote
My brother's blade started leaking coolant from the water pump bleed hole. We stripped the pump down using my hydraulic press and found that the mechanical seal had a split bellows. Honda will only sell a new pump at over £200 and any used pump is going to be risking the same problem as the rubber seals will be similarly hardened over time so there was nothing to do but change the seal.
Easier said than done as it happens because Honda used a Type 73 SPECIAL seal that's an odd size. The seal face and ceramic rotor are identical to a standard £10 seal but they used an over-sized dish to mount the static part. New seal on the left, old seal dish on the right in the pic.
https://peterrimmer.myby.co.uk/images/blade_pump01.jpg
So we need a way to mount the new seal in the hole. We decided to bond it into the old dish, so first job is to cut off the base of the dish to make a ring. I jammed the thing onto a tip-ex pen to hold it and ground the corner away on my bench grinder to cut the base away from the dish.
https://peterrimmer.myby.co.uk/images/blade_pump02.jpg
https://peterrimmer.myby.co.uk/images/blade_pump03.jpg
leaving us with all these bits to assemble:
https://peterrimmer.myby.co.uk/images/blade_pump04.jpg
Bonded the new static seal into the ring of the old one. No need to be super-fussy as it doesn't spin but the tapered lip does a good job of keeping it central anyway:
https://peterrimmer.myby.co.uk/images/blade_pump05.jpg
But now the seat is 1mm thicker so turn 1mm off the face of the pump to give the right spring pressure:
https://peterrimmer.myby.co.uk/images/blade_pump07.jpg
Press in the shaft:
https://peterrimmer.myby.co.uk/images/blade_pump08.jpg
Sealant on the seal and new ceramic in the impeller:
https://peterrimmer.myby.co.uk/images/blade_pump06.jpg
Finally press in the seal:
https://peterrimmer.myby.co.uk/images/blade_pump09.jpg
Impeller was pressed back on and it's all like new again. Job done for a tenner and a couple of hours work.
barrkel
PostPosted: 00:16 - 11 Apr 2015    Post subject: Reply with quote
And a lathe and hydraulic press and grinder and space to keep them all Smile
Iain.
PostPosted: 10:53 - 11 Apr 2015    Post subject: Reply with quote
barrkel wrote:
hydraulic press....space to keep them all Smile
Doesn't everyone have one of these in their kitchen? Confused
PostPosted: 20:37 - 11 Apr 2015    Post subject: Reply with quote
You work with what you've got. Strictly there's no need for the lathe or the press, the job could have been done with just the grinder and a bit of ingenuity but this way was easiest.
The last post was made 10 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 43.38 Kb
