'97 DTR 125 No Electrics Except Headlights.
Boxing
PostPosted: 15:27 - 09 Apr 2015    Post subject: '97 DTR 125 No Electrics Except Headlights. Reply with quote
Hi all, as above, none of my electrics are working except my headlight. It has a spark and starts, but no brake lights, nothing. Just headlight working.
No N light on the clocks, no temperate gauge, nothing.
I've checked the fuse, it's fine. I'm running out of ideas.
Thanks in advance for the help. Very Happy
Taught2BCauti...
PostPosted: 06:37 - 10 Apr 2015    Post subject: Reply with quote
Was it like that when you got it, or did you discover it after a period of storage, or did it suddenly happen on a ride?
I'm sure there's more than one fuse though - does it mention them in the manual?
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Boxing
PostPosted: 01:01 - 11 Apr 2015    Post subject: Reply with quote
It's my daily rider. Went out for a ride, midway through I noticed my temperature gauge had gone down to nothing, then my N light wasn't working. And then I realised my indicators and brake light had stopped working.
As far as I'm aware there's only a main fuse.
Taught2BCauti...
PostPosted: 07:55 - 11 Apr 2015    Post subject: Reply with quote
According to the Wiring Diagram, there is indeed only one fuse -so check for loose, broken or damaged wires, loose or corroded connectors.
Copycat73
PostPosted: 08:09 - 11 Apr 2015    Post subject: Reply with quote
and the battery ... wot is its condition ?
caveat emptor
Boxing
PostPosted: 13:23 - 15 Apr 2015    Post subject: Reply with quote
Charges fine off the bike when riding. But the brake light should work off the engine anyway. I've blown fuses before and everything worked fine off the engine except the indicators.
I'll investigate the loom properly soon. I suspect it's the wires to the rear brake shorting somewhere.
Copycat73
PostPosted: 20:24 - 15 Apr 2015    Post subject: Reply with quote
try replacing the bulb .... seen a defective one cause some weird problems.
caveat emptor
The last post was made 10 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 51.62 Kb
