| Ribenapigeon |
 Ribenapigeon Super Spammer
| Islander |
 Islander World Chat Champion
| Suntan Sid |
 Posted: 11:49 - 10 Apr 2015 Post subject: |
You need to anneal the aluminium before bending!
Basically rub some soap onto the surfaces, heat gently, then bend.
Google "annealing aluminium" something will pop up on youtoob with a demo. ____________________ "Everybody needs money, that's why they call it money!"  |
| Nexus Icon |
| Ribenapigeon |
| Nexus Icon |
| Copycat73 |
 Copycat73 World Chat Champion
| bladerunner |
 Posted: 17:47 - 10 Apr 2015 Post subject: |
Aluminium is more likely to crack if bent very hot than cold as it passes through a brittle stage just before it gets to melting temp. Anneal it, let it cool, bend it. ____________________ a.k.a 'Geri'
 Posted: 18:01 - 10 Apr 2015 Post subject: |
Also the direction you bend rolled plate/sheet in makes a huge difference. It's much more ductile in the direction it's been rolled so if you can see the grain always bend it in that direction or it'll surface-tear on the outside of the bend. ____________________ a.k.a 'Geri'
| ZRX61 |
 ZRX61 Victor Meldrew
| Ribenapigeon |
| c_dug |
 c_dug Super Spammer
| Ribenapigeon |
 ........................ Spanner Monkey
| Ribenapigeon |
| kramdra |
 kramdra World Chat Champion
| Ribenapigeon |
 Posted: 00:02 - 12 Apr 2015 Post subject: |
You will geat away with one bend in 4mm bar. Bend it directly to the correct position first time.
Giving it a few heating/cooling cycles AFTER bending it will massively releive the internal stresses. For most aluminium, giving it an hour in your kitchen oven set to its maximum temperature then allowing ti to cool 'till it can be safely handled will work wonders. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 10 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
