problem with kick down
mr.gio
PostPosted: 18:41 - 10 Apr 2015    Post subject: problem with kick down Reply with quote
hello all
it my first post, so beg my pardon if i made any rules violation
i ride on 07 suzuki sv650s
when i am riding and going to brake and transfer gear down, in the moment when i pulling clutch fully engine turns off
if trying to pull it slowly and little by little, its does not turns of always
during accelerations and transferring in upper gear engine does not powers off
can anyone say me what is the problem?
its terrible, engine powers off before turning ...
PostPosted: 21:22 - 10 Apr 2015    Post subject: Reply with quote
And the last time you changed the oil, oil filter, air filter and spark plugs was... ?
Mileage is?
Valve clearances were checked at?
bikenut
PostPosted: 09:53 - 11 Apr 2015    Post subject: kill Reply with quote
are you saying the engine dies when the steering is turned??
do any light stop working when the steering is turned??
I presume there is lots of petrol in the tank.........and the wires from frame to headlamp/head stock are not being or have been trapped and mangled......
nuts about bikes
Taught2BCauti...
PostPosted: 12:08 - 11 Apr 2015    Post subject: Reply with quote
Mileage is?
It would also help to know the circumstances leading up to this problem - like, has it always done this, or started doing it after some event, such as having the bike worked on, changing a part, or having a spill?
So far, my guess would be dodgy wiring around the CDI or ignition switch.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 13:08 - 11 Apr 2015    Post subject: Re: kill Reply with quote
I read it as: dies between gears at idle with the clutch pulled in, when riding at slow speeds (i.e. low revs).
Weak spark, bad fuelling, hooky valve clearances, goblins. INSUFFICIENT DATA FOR MEANINGFUL ANALYSIS.
Commuter_Tim
PostPosted: 16:52 - 11 Apr 2015    Post subject: Re: kill Reply with quote
Apologies, A metaphysical dichotomy has forced this Rogerborg to overload and shut down.
BCF International would like to apologize for any inconvenience this may cause.
A credit note will be forwarded to your company immediately.
I ride a Bandit 600... badly.
mr.gio
PostPosted: 16:57 - 11 Apr 2015    Post subject: Reply with quote
thank a lot to all for replays
well
oil changed 1000 km ago, now i am going to change oil, air and oil filter and spark plugs. valve clearance isnt checked, so i will try to do it
engine when working holds 1500 rpm, is it normal?
milage is 19000 KM
bikenut
no , its not powers off when moving steering, its turns off in the moment of clutch using during braking
Taught2BCautious
when i bought this bike dyno jet III was installed on it and the problem were already
i didn't changed anything in electricity
Nobby the Bastard
Harley Gaydar
PostPosted: 18:59 - 11 Apr 2015    Post subject: Reply with quote
No, 900 rpm is normal.
mr.gio wrote:
milage is 19000 KM
Not massive milage but a valve clearence check wouldn't hurt.
Restore it to standard. Sounds like someone has tried to tune it, to the detriment of the bottom end.
Triumph Sprint ST 1050
mr.gio
PostPosted: 17:50 - 13 Apr 2015    Post subject: Reply with quote
Vincent
no, its starts without clutch lever pulling
Nobby the Bastard
well
i will try replace of spark plugs filters oil, clean intake and if no result than i will remove powercomander
thanks to all and i will write here results
bikenut
PostPosted: 10:23 - 15 Apr 2015    Post subject: stops Reply with quote
how you getting on....found a bad connection on the ign somewhere yet??
nuts about bikes
The last post was made 10 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 69.67 Kb
