| Nipedley |
 Nipedley Scooby Slapper
 Posted: 16:19 - 10 Apr 2015 Post subject: My lever is too stiff |
Oo er
My CBR's front brake lever is bloody stiff, I haven't used it much over winter so not sure if this has contributed.
It's not smooth, it's like it 'clicks' through the travel, the first click from resting is most of my regular braking exertion and does very little braking. The next click requires a lot of force, and brakes very hard. Once it grabbed so tight it actually locked the front wheel, all with barely any lever travel.
The brakes aren't binding at all, both calipers were fully rebuilt last year and regularly cleaned, (last had fresh brake fluid maybe July/Aug last year?) it's a dual disc and running EBC HH pads on both sides (non-sintered EBC did bugger all)
I'm gonna pull the lever(s) and clean and put some lithium grease on the pivots, but wondered if you guys might have any other ideas
Cheers! ____________________ CBR600 (1988) | GS500 (1989) |
| Fisty |
 Fisty Super Spammer
| Nemo |
 Nemo Could Be A Chat Bot
| bikenut |
 bikenut World Chat Champion
| Nipedley |
 Posted: 10:07 - 11 Apr 2015 Post subject: |
I should have mentioned, I rebuilt the M/C last year too. The previous owner was a spaz and bodged a half seized M/C with springs to push and load the lever so that you couldn't tell it was half seized, horrific picture attached. It actually caused the front brake to seize on and crash which has left me with some nerve damage in my left hand (worst bodge)
Sounds like the grease should do the job, if not I'll post back. It's likely never been lubed since it was put on new. Cheers!  ____________________ CBR600 (1988) | GS500 (1989) |
| bikenut |
| Nipedley |
 Posted: 12:11 - 11 Apr 2015 Post subject: |
Hey there,
Yeah it just occured to me to take a pic at the time, I hadn't finished putting it back together at that point (getting that seal down over was quite the pain) I used red rubber grease during it as I'd used that for rebuilding the calipers as well. I did check the port at the bottom of the M/C and that was all good
The bike was fine after the M/C rebuild (would have been January 2014? Put about 4000 miles on since then), it just seems to be bad now after the winter, so fingers crossed it's just the lever needing a good clean and lube (it is a previously badly neglected 27 year old bike) - if not then I'll drop the fluid and have another look at the M/C. I did check when I first noticed the issue the condition of the M/C dust seal and that's all fine still ____________________ CBR600 (1988) | GS500 (1989) |
| kramdra |
 kramdra World Chat Champion
The last post was made 10 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
