cheap compression tester
sutty86
PostPosted: 10:53 - 11 Apr 2015    Post subject: cheap compression tester Reply with quote
Just bought one off the bay is there suppose to a specific size socket
As there is nothing what fits with this kit...
Presume they would be universal
https://pages.ebay.com/link/?nav=item.view&id=331515680453&alt=web
Taught2BCauti...
PostPosted: 11:58 - 11 Apr 2015    Post subject: Reply with quote
Yes, they are universal. You should be able to figure it out just by looking at it - if not, remove a spark plug and look at the threaded part to give you a clue.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
sutty86
PostPosted: 13:36 - 11 Apr 2015    Post subject: Reply with quote
Tried earlier on with all adapters none fit, all too big, spark plug is standard size
Will take pics later on
PostPosted: 14:29 - 11 Apr 2015    Post subject: Reply with quote
There are several 'standard' sizes of spark plug. Looks like you'll need a 10mm or 8mm adapter for your gauge.
sutty86
PostPosted: 16:11 - 11 Apr 2015    Post subject: Reply with quote
https://i.imgur.com/b3w2U3q.jpg
PostPosted: 16:47 - 11 Apr 2015    Post subject: Reply with quote
Like I said - you need an adapter.
alexknight200...
PostPosted: 11:49 - 12 Apr 2015    Post subject: compression tester Reply with quote
Where would you be able to get an adapter from?
Current stable: Yamaha XVS 650 1996 - Honda Super Magna VF750 1988.
kramdra
PostPosted: 12:38 - 12 Apr 2015    Post subject: Re: compression tester Reply with quote
Looks good, better than the 20 quid gunson branded shite. Are there adaptors on ebay? uk stuff costs more than your tool Laughing I think gunson wanted 16 quid for one.
There are adaptors with a rubber end, to be held against the plug hole, thats a bit more universal but more effort to use.
Adaptors, easily made. smash the ceramic from an old plug, clean it up, and braze (or solder) it to one of the included adaptors (remove orings first). Ive done this many times, usually solder. If soldering, pre-tin both parts, it needs to be good joint to hold upto 14 bar Laughing
PostPosted: 12:46 - 12 Apr 2015    Post subject: Re: compression tester Reply with quote
Well, personally I would make one, but that's only an option if you have the facility. I doubt there's a 'one size fits all' because some bikes have a very deep plug well and others very little clearance.
THIS ONE would seem to be a good sized adapter though.
kramdra
PostPosted: 12:59 - 12 Apr 2015    Post subject: Re: compression tester Reply with quote
Would the 8mm part not protrude and fuck a piston in a 10mm hole Thinking
sutty86
PostPosted: 13:00 - 12 Apr 2015    Post subject: Reply with quote
Cheers lads
Tbh the kit has very negative reviews on amazon but only read them once I received yesterday...
Yes my bike is very deep and awkward, cheers for the link
Not the greatest with diy/toolwork even though I try ....
Think I will buy the adapter
PostPosted: 16:44 - 12 Apr 2015    Post subject: Reply with quote
The one I linked doesn't have an 8mm end, the smallest size is M10.
The last post was made 10 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 81.07 Kb
