SLi Issues - Not detecting second card
Jayy
Mr. Ponzi
PostPosted: 18:17 - 11 Apr 2015    Post subject: SLi Issues - Not detecting second card Reply with quote
This is going to be a long post, in before TL:DR.
I have an SLi setup which has been running fine for the first year or so (forget how long I've had them), then I stopped gaming completely. My bro asked if I could put one of the cards in my second rig so he could use it, I agreed. The other rig had the 2nd card in it for some 6 months before I took it back. Since putting it back, I noticed the SLi wasn't working, so I began going about trying to locate the issue.
My Setup
ASUS Sabertooth Z77 Board
i7 3770k Ivybridge CPU (Stock)
Corsair H60 water cooler
16GB Corsair 1600mhz DDR3 Vengeance memory (Currently split 8gb in this machine and 8 in the other)
Gigabyte GTX 680 4GB cards x 2
1000w Coolermaster Silent Pro PSU
Win 8.1 64x OS
Intel 520 SSD's in RAID 0 for OS
That's the important stuff for the purpose of this thread.
The Problem
It seems that the second card in PCI slot 2 isn't being detected at all. Not in device manager (usually shows up twice for SLI), not in the BIOS (Shows "Not detected") and not in Nvidia control panel.
What I've tried:-
Flashing the mobo from 1 behind the latest BIOS to the latest just now.
Brand new SLi bridge to replace the old one (doesn't matter anyway, doesn't detect the card in PCI slot).
Having the SLi bridge on every possible way, including both sets of SLi ports.
Swapping the cards around in the PCI slots 1 and 2 (When in slot 1, each card works perfectly).
Having singular cards run in Slot 1 (Works fine).
Having singular cards run in Slot 2 (Neither work, black screen, no BIOS, nothing but I hear it boot in to Windows).
Resetting the BIOS to optimised defaults.
Resetting the CMOS to see if the PCI lanes would reset.
Changing the power cables to the cards.
Using the latest Nvidia drivers currently. Tried beta drivers and rolling back several months.
Making sure the PCI config in the BIOS is set to 8x / 8x for Slot 1 and 2, instead of 16x for Slot 1 and all others disabled. ( There is a 3rd PCI but because these cards are so big, it can't fit ).
What I think
If the PCI slot 2 was completely fucked, it wouldn't power the card? The fans spin and everything powers up on the second card, so don't think it's that. I can't see any bent pins in the PCI slots, so don't think it's that. There's no dodgey connectors on the cards and they work in Slot 1 with both cards in and with single card in.
The ONLY thing I'm left with now is the fact that I can't remember if I was on Windows 7 Ultimate 64 when I was fully utilising the SLi setup (which I may have been) or if I had upgraded to Win 8 at the time and now currently on Win 8.1 Read a lot about Win 8 fucking up SLi for people and it could be a possibility, as I have also seen a thread about Lenovo machine and applying a patch for SLi on Win 8.
Don't really want to downgrade to W7 but I think it may be the last ditch attempt to see if that's the issue as I "think" that was the last time I had the SLi setup running fine.
There is a 5 year warranty on these boards but it's 1 month for the RMA process, if you're lucky.
In two minds whether to just upgrade the whole thing, new mobo, cpu, ram.
Jayy
Mr. Ponzi
PostPosted: 19:47 - 11 Apr 2015    Post subject: Reply with quote
Thinking about it, as tempting as it is to just upgrade everything, I might just sell them cards.
The i7 and mobo are fine (aside from the SLi issue) and I don't game that often really anyway. My other rig which has an i7 (First gen) in it, is still going strong and performance wise, nothing wrong with it.
The only thing that's depreciating in value here is the GPU's.
I paid near £500 per card for the 680's a couple years ago. I think they would fetch £400 odd for the pair now? I don't know, the card of the moment seems to be the GTX 980 but a pair of 680s will out perform a single 980.
Hmmm, will have a think about this.
CaNsA
PostPosted: 19:50 - 11 Apr 2015    Post subject: Reply with quote
You have a mobo with a 5yr warranty but you wont RMA it?
Are you mental?
Jayy
Mr. Ponzi
PostPosted: 20:30 - 11 Apr 2015    Post subject: Reply with quote
I will RMA it but as this is my main rig, I need something as good in the meantime. The other rig would probably hold up for a month but I was just pondering with the idea of upgrading everything and RMA'ing the mobo anyway and either sell it or build a 3rd rig.
trevoriv
PostPosted: 23:15 - 11 Apr 2015    Post subject: Reply with quote
Don't you have to tell the nvidia software that you're running two cards, I'm sure I had this problem when I put my gtx's in sli.
Jayy
Mr. Ponzi
PostPosted: 00:03 - 12 Apr 2015    Post subject: Reply with quote
You do have to turn SLi on but it usually has an option that says "Configure SLi and Physics".
https://i.imgur.com/F6wJKSL.png
If it doesn't detect the second card in your system at all, it won't show the SLi options.
If you go to Device manager > Display adapters in Windows, it should also include your card twice but mine shows only one.
The biggest indicator is the BIOS says "Not detected" in PCI Lane 2.
CaNsA
PostPosted: 00:24 - 12 Apr 2015    Post subject: Reply with quote
Deffo no settings in the bios to enable that specific pci slot?
Ayrton
PostPosted: 00:34 - 12 Apr 2015    Post subject: Reply with quote
Might be Win 8 causing the problem. I've heard that a lot of people have had issues running 2 cards with it and it's a pretty crap OS anyway.
If i was you i'd sell the 2 cards and get a 290. You would get more than enough to cover it and you wont have to put up with all the issues that come with SLI. You could get lucky like my brother did and find one on ebay for £100 Laughing
Jayy
Mr. Ponzi
PostPosted: 00:55 - 12 Apr 2015    Post subject: Reply with quote
Nope, just X1 mode or X4, which is Slot 1 enabled only, or all enabled.
Ayrton, it's a possibility but I wouldn't buy another AMD card, rather stick with Nvidia. I never had any issues with SLi in games, worked flawlessly in anything I played, just seems that the PCI slot is goosed now.
CaNsA
PostPosted: 01:22 - 12 Apr 2015    Post subject: Reply with quote
From https://www.tomshardware.co.uk/answers/id-2368451/trouble-running-sli-asus-sabertooth-z77.html
In BIOS, System Agent Configuration, Graphics Configuration, try setting Primary Display to PEG and test again the second slot with single card. If still the same, then it might be a board or a bent pin issue.
Jayy
Mr. Ponzi
PostPosted: 01:26 - 12 Apr 2015    Post subject: Reply with quote
Saw that on Toms Hardware, tried it and nothing happened.
CaNsA
PostPosted: 01:28 - 12 Apr 2015    Post subject: Reply with quote
PEBKAC
CaNsA
You havent got any MVP stuff going on?
Ayrton
PostPosted: 01:34 - 12 Apr 2015    Post subject: Reply with quote
Why not? I've had a pretty good experience with all the AMD stuff i've owned recently. I should have recommended the 780 as well to be honest, but i don't think anyone should give them money after what happened with the 970.
Jayy
Mr. Ponzi
PostPosted: 17:13 - 12 Apr 2015    Post subject: Reply with quote
Nope, all that is off.
I hadn't changed the BIOS since removing one of the cards and giving it to my bro for 6 months, nothing had changed, other than maybe Win 7 to 8.
I will try downgrading to Win 7 again, just to rule it out.
Jayy
Mr. Ponzi
PostPosted: 17:20 - 12 Apr 2015    Post subject: Reply with quote
I've had many AMD cards and my experience with the drivers was worse than with Nvidia.
Had a HD 5870 for a few years, HD6990 for a few years and even though that was a £600 card, it cause me more issues with drivers than any other card I have ever owned. I know they were dual cards on a single slot but still, the 5870 I had before it was also a top end card but was awesome.
Never had any driver issues since being with Nvidia again after the last card I owned was a 9800GT, many years ago. I personally wouldn't buy one yet, until Nvidia piss me off?
Bit like AMD vs Intel, nout wrong with AMD but I wouldn't buy one!
The last post was made 11 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 87.73 Kb
