Aprilia rs125 cutting out when riding
Henry2202
PostPosted: 18:19 - 11 Apr 2015    Post subject: Aprilia rs125 cutting out when riding Reply with quote
Hi,
I bought an rs125 2006 15k miles restricted about a month ago, started having problems a week ago, was doing about 50mph and it lost all power and cut out when I stopped, I tried starting it for 5 mins and it finally started, it has since done it 3-4 times more, at random times eg. Sometimes 2 mins into ride, sometimes 20 mins, its got a new plug, I cleaned the carb and still no luck but did notice a small spring in the carb broken? Also it has been idling strangely lately, sometimes 3k and sometimes 6k when I first start it? It was idling fine prior to this and I've not messed with the speed, do these have an auto choke as we'll or could the choke be sticking causing it to cut out because it was spluttering yesterday before it cut out. Any ideas? Cheers
Nobby the Bastard
Harley Gaydar
PostPosted: 19:01 - 11 Apr 2015    Post subject: Re: Aprilia rs125 cutting out when riding Reply with quote
Henry2202 wrote:
Hi,
It's the HT coil. As it gets hot it fails. When it cools down it starts to work again.
Triumph Sprint ST 1050
Henry2202
PostPosted: 19:12 - 11 Apr 2015    Post subject: Reply with quote
Vincent wrote:
What does the bust spring look like? Any photos?
It's the size of a pen spring, looks like it connects to choke cable, not sure if it was broken or I broke it as was brittle and rusted
Henry2202
PostPosted: 19:15 - 11 Apr 2015    Post subject: Re: Aprilia rs125 cutting out when riding Reply with quote
[/quote]It's the HT coil. As it gets hot it fails. When it cools down it starts to work again.[/quote]
Cheers, will order one and see what happens
Henry2202
PostPosted: 19:43 - 13 Apr 2015    Post subject: Reply with quote
So ive just rid it and it's very loud and spluttering and I've noticed a hole in the exhaust, could this be why it's cutting out? Also can I ride it in the meantime? Cheers
Nobby the Bastard
Harley Gaydar
PostPosted: 20:41 - 13 Apr 2015    Post subject: Reply with quote
It may run badly with a hole in the exhuast, but it will generally run.
It's not heat seizing, is it? You won'T be able to kick it over at all until it cools down.
P.
PostPosted: 21:18 - 13 Apr 2015    Post subject: Reply with quote
Could be bearing failure, seizing, anything. When was it rebuilt last.
The last post was made 10 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 56.02 Kb
