Honda CB1000R Wont Start
chrisbmxr
PostPosted: 15:13 - 13 Apr 2015    Post subject: Honda CB1000R Wont Start Reply with quote
Hi All,
I wondered if anybody could help me with an issue I've got with my 2009 Honda CB1000R.
Since replacing the battery, I've kept the bike on charge using an Oxford Oximiser charger, but when I go to start the bike 95% of the time it wont fire. I turn the ignition on, and the fuel pump primes and everything seems normal. When I go to start the bike the engine turns over as quick as you would expect, but it just doesn't kick into life. I've tried throttle open / throttle closed, on side stand / off side stand but it's still the same. I'm fairly sure it's getting fuel, as after a few attempts at starting I'm sure I can smell fuel through the exhaust.
Last night I managed to get it to fire up, and once running it was absolutely fine! It runs a treat. But after letting it run for a while I switched it off and it wouldn't restart.
It will bump start, and does usually bump start on the first attempt.
Any thoughts would be much appreciated, as I'd like to get this issue resolved before my tour of Scotland (booked for 4 weeks time), and I'd like to avoid main dealer bills if possible!
Bike is a 2009 (non ABS), with up to date service history.
Thanks Guys,
A concerned CB1R owner
Peugeot Speedfight 2 50cc -> Gilera Cougar 125 -> Honda Hornet 600 (2005) -> Honda CB1000R
P.
PostPosted: 15:51 - 13 Apr 2015    Post subject: Reply with quote
You have a Honda with electrical issues. Such surprise, much reg rec, wow.
Get it running again and then check the voltage across the battery. You want a nice solid 13.5+, aiming for around 14 really.
Anything less than 13, or you'll see stuff like 12.2, 11.9 etc etc then you may have a fudged regulator, Honda standard.
Check the stator outputs, so unplug reg rec, check AC V from stator, 3 yellow wires usually, + on there, - on frame, should see an equal amount on each wire, would guess going on my old Blackbird readings, between 55 and 70v AC on each.
If that is good, regulator, if not, stator.
Copycat73
PostPosted: 16:02 - 13 Apr 2015    Post subject: Reply with quote
please state millage of bike..
and specify the services that have been done and when.
caveat emptor
andys675
PostPosted: 19:43 - 13 Apr 2015    Post subject: Reply with quote
did you give the battery a full charge before you fitted it? what brand is it?
YTZ10s? too fecking small
gorillaonabik...
PostPosted: 21:26 - 13 Apr 2015    Post subject: Reply with quote
Had numerous Hondas and numerous regulator rectifiers. If it isn't the reg rec then I'd be surprised.
FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell.
evoboy
PostPosted: 23:34 - 13 Apr 2015    Post subject: Reply with quote
This.
Battery.
APT Motorcycles
The last post was made 10 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 48.58 Kb
