CR8E / CR9E
Pigeon
PostPosted: 19:57 - 14 Apr 2015    Post subject: Reply with quote
Given the plug is colder, it may well foul easier as it struggles to get hot enough to self clean / burn off.
I'd look at the state of the plugs that came out. If they are tan, or even show signs of overheating / blistering, then bumping 1 in the heat range would probably be ok.
If the plugs are already black / oily, then I wouldn't use the 9.
bikenut
PostPosted: 10:20 - 15 Apr 2015    Post subject: heat Reply with quote
with ngk, a higher number means a cooler plug, ie gets rid of more heat........champion ( wtf are they these days ) its opposite.
nuts about bikes
Iain.
PostPosted: 14:49 - 15 Apr 2015    Post subject: Re: heat Reply with quote
Excellent plugs, especially for fine tuning the two smokes as they've got stuff that'd equate to an 8.5 and simmilar in NGK heat gradings.
Should be fine running them in the summer, winter you might want to swap back to the 8's though.
PostPosted: 18:51 - 15 Apr 2015    Post subject: Re: CR8E / CR9E Reply with quote
BodyGuard wrote:
The new plugs I bought for my Fazer are 9E I did not realise when buying though they did say Fazer in the add.
Anyway the Haynes suggests use CR8E and these which are possibly the originals are in the bike at present.
What is the difference between the plugs hot/cold I understand but should I be concerned replacing them with 9E's rather than 8's.
Just put them in and ride it.
Thorn This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 10 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 49.38 Kb
