DIY Bolt Spacer
BillyJ
PostPosted: 14:22 - 16 Apr 2015    Post subject: DIY Bolt Spacer Reply with quote
I need to make some spacers that are m7/8 ID, OD doesn't matter and they need to be 75mm long.
What is the easiest DIY way of doing this. My only option I can see is to buy a set from eBay of 25mm ones and stack them?
THESE:
https://i.ebayimg.com/00/s/MTYwMFgxNjAw/z/aPYAAOSwabhUVqfI/$_57.JPG
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
SQL
PostPosted: 14:33 - 16 Apr 2015    Post subject: Reply with quote
75mm of Washers
Raffles
PostPosted: 15:07 - 16 Apr 2015    Post subject: Re: DIY Bolt Spacer Reply with quote
BillyJ wrote:
My only option I can see is to buy a set of 25mm ones and stack them
That's exactly what I did recently. I then got them tacked together by Bodyguard's welder.
BillyJ
PostPosted: 15:46 - 16 Apr 2015    Post subject: Re: DIY Bolt Spacer Reply with quote
But that's a pro job with a pro welder with experience... I asked for DIY Wink
Haha, but seriously, I'm guessing that's the only option then... Confused
bugeye_bob
PostPosted: 16:05 - 16 Apr 2015    Post subject: Reply with quote
could you not buy some tube of correct dimensions and just cut off the spacer you need ?
Failing that some round bar and drill to suit.
moonzoomer
PostPosted: 22:17 - 16 Apr 2015    Post subject: Reply with quote
You can buy these from most good hardware outlets in various metric threads, they come in various lengths and can be cut to suit your needs with the added advantage that 2 short bolts are needed for fitment and adjustment, they may be suitable for your needs as they are stackable via stud iron
https://www.ebay.co.uk/itm/A2-Stainless-Stud-Connectors-Long-Nuts-Threaded-Bar-Rod-M5-M6-M8-M10-M12-M16-M20-/281109754565?pt=LH_DefaultDomain_3&var=&hash=item41737272c5
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 47.28 Kb
