| talkToTheHat |
 Posted: 17:07 - 16 Apr 2015 Post subject: UPDATE: vapour lock? was floats, fuel pump, blocked fuel... |
My 535 has an over-frame tank that gravity feeds a larger underseat tank. This then has a petcock beneath which routes fuel into a tube that runs back through the underseat tank, exiting on top, through a fuel filter, to a fuel pump beside the tank, then up to the first carb by a long hose. A translucent silicone hose connrcts the two carbs together.
Usually when I turn the bike on the fuel pump fires for maybe 3 or 4 beats before shutting off. Today it has been shutting off on timer and running faster like I am out of fuel or there is air in the system. I have done 50 miles since my last fillup so I should have that again until bone dry at the very worst, shaking the bike sounds like the underseat tank is nearly full. There is a small bubble in the silicone hose between the carbs, this does not appear to be moving, so fuel is not being pumped into the front carb, or flowing back from the top hose into the rear carb.
On draining, both carbs came out clean. I drained the rear carb first and the bubble moved so I don't think its floats.
I just changed oil and filter, air filter, and fuel filter.
Thoughts? Seriousness. Have done 30 miles or so on the bike today and bike has felt fine.
Could it be just heat soak into the fuel line causing vapuour lock?
What should I check next or is it panic and garage time? ____________________ Bandit. does. everything.
| davebike |
 davebike World Chat Champion
 Posted: 06:27 - 17 Apr 2015 Post subject: |
Fuel tap ??
the electric main /reserve tap is a common source of problems on the e535 been left unused over winter ?? ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| talkToTheHat |
| talkToTheHat |
| davebike |
 Posted: 12:13 - 17 Apr 2015 Post subject: |
Pipe touching head Had this problem with a Harley
Wrap it in two layers spiral wrap as used the tidy swingeing sorted the Harley
I have seen the "change over " tap block , stick half way neither on! etc worth using it on / res / on on every ride ____________________ Dave
| talkToTheHat |
| davebike |
| mysterious_rider |
 mysterious_rider World Chat Champion
| talkToTheHat |
The last post was made 10 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
