| blinkinink |
 blinkinink L Plate Warrior
| mudcow007 |
 mudcow007 World Chat Champion
| blinkinink |
 Posted: 09:26 - 17 Apr 2015 Post subject: |
yes in 10 years 3 boiled batteries.
Was that not clear ...........why? is that normal with a optimiser?
I purchased the optimiser to maintain batteries and have seen forums where the users have NEVER replaced batteries.
The question was..... is this optimiser knackered or is there a solution by adding a timer to the optimiser |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
 Posted: 09:31 - 17 Apr 2015 Post subject: |
| blinkinink wrote: | yes in 10 years 3 boiled batteries.
When I have sat mine up, I never had it connected permanently. I'd put it on for a couple of days then disconnect for a week.
Can't say this will solve your problems. Do you connect the optimate when you are riding, so when you park up you clip it on or ONLY when laying up?
If you are having it on even when riding, your charging system could be fuggered and is draining your battery while riding, then it's being charged up again when home rather than being maintained, if that makes sense. ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
| G |
 G The Voice of Reason
| mudcow007 |
| Islander |
 Islander World Chat Champion
| blinkinink |
| DrSnoosnoo |
 Posted: 10:38 - 17 Apr 2015 Post subject: Re: Optimate constantly charging |
| blinkinink wrote: | I ride it without the optimiser,
The bike has an alarm connected, so the optimiser is connected to it whenever it is parked in the garage...........bike is only used occasional weekends in the summer, only done 2,000 miles.
ps I purchased the latest new battery 2 weeks ago, rode it for 1-2hr. connected the optimiser and it has been charging for 2 weeks constantly (on the orange light),....should this happen with a new battery?
Thanks for the helpful replies guys
I will test the voltage after its been connected for a while. |
The orange light just means it's on and it constantly trickle charges once it's up to the designated voltage and what have you.
The alarm shouldn't be discharging the battery faster than the optimate can fill it but I reckon when you're riding for 1 or 2 hours, your charging system is buggered and is not charging your battery properly, either under or over so it's working your battery hard. The optimate is recovering it in between rides but the battery can only suffer these cycles a finite number of times. ____________________ I'm Sam; Northern, Ginger, Lover
| mudcow007 |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 13:15 - 18 Apr 2015 Post subject: |
I'd buy a decent meter before an Optimate.
As said, you need a meter to check the bikes charging system and optimate function.
Most batteries have a 2 year guarantee so 10 years is beyond
supported use for 3 batteries.
Crap batteries perhaps? I've used many batteries past the 2 year mark but they were used a lot
I use a Mascot charger from a UPS bank which has three colour leds
Red for bulk charge
Orange for topping/saturation
Green for float/trickle
My Lidls charger has the same functions
Both drop to say 13.5-13.7 on float/green and i check them from time to time
Are you saying your Optimate has the same process but stays on
orange/saturation rather the moving to green/ float?
Here's a useful page on LA battery charging
https://batteryuniversity.com/learn/article/charging_the_lead_acid_battery ____________________ bikers smell of wee |
| kramdra |
 kramdra World Chat Champion
 Posted: 15:52 - 18 Apr 2015 Post subject: |
Get a decent charger to begin with. Any decent charger ** will ** have a display to show the voltage and/or charging current. Automotive chargers will be massively overpriced and generally shit - many have fixed charge rates and no over-voltage cut off, which will boil batterys . Any charger without a display should be considered to not have a cut off and needs an external meter to check them.
I have an Imax B8, this is slightly cheaper version: https://www.hobbyking.com/hobbyking/store/__28146__IMAX_B6_50W_5A_Charger_Discharger_1_6_Cells_GENUINE_UK_Warehouse_.html
This was able to bring back three Pb batterys that were left flat for about 6 months, no issues since, they work like new. A halfords charger was not able to charge them
Check charging system on bike. Batterys do not need constant float charging, top it up once or twice a month over winter if your not using it. |
| evilzed |
 evilzed Scooby Slapper
| Robby |
 Robby Dirty Old Man
The last post was made 10 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
