How important is priming an oil filter?
Wonko The Sane
PostPosted: 11:24 - 19 Apr 2015    Post subject: How important is priming an oil filter? Reply with quote
I've always been told you should prime an oil filter when fitting and a thin smeer of oil on the seal and hand tighten.
On the ZZR the filter sits horizontally behind the exhaust and oil cooler making it hard to get the filter on without getting oil all over the exhausts and my hands making it hard to ensure its tight.
This often results in a small leak or spray onto the exhaust 500 miles or so later
Any ideas?
Is not priming a big issue if I bump the motor on the starter a few turns before firing?
Nemo
PostPosted: 12:06 - 19 Apr 2015    Post subject: Reply with quote
I don't "prime" them, I smear a bit of oil on the seal and nip up with a filter wrench.
Start the bike, watch and make sure the oil light goes out, leave running for 5 mins, turn off, check level and top up after a couple of mins.
Never had a problem.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Rogue_Shadow
PostPosted: 12:19 - 19 Apr 2015    Post subject: Reply with quote
Same as above
Never "primed" a new filter but I do smear some of the new oil on the seal.
Andy_Pagin
PostPosted: 12:20 - 19 Apr 2015    Post subject: Reply with quote
Priming filters really only applies to big car engines, V8s and the like with filters the size of a small saucepan, especially those with remote filtering systems.
For bikes just smear some oil around the seal and hand tighten as hard as you can. Using a wrench is risky unless you're very careful.
Next fill up with oil.
Run the engine, check the oil light goes out, let it warm up, check for leaks.
WD Forte
PostPosted: 12:30 - 19 Apr 2015    Post subject: Reply with quote
I often do it cos its easy on my bike
and always do it after a rebuild.
I whip the plugs out and spin it up on the starter until
the oil light goes out.
bikers smell of wee
PostPosted: 12:41 - 19 Apr 2015    Post subject: Reply with quote
Not usually. One some bikes it's almost essential though.
c_dug
PostPosted: 13:13 - 19 Apr 2015    Post subject: Reply with quote
I always have. Never struggled much either to be honest.
Copycat73
PostPosted: 19:32 - 19 Apr 2015    Post subject: Reply with quote
I prim all filters I fit ...
caveat emptor
J4mes
PostPosted: 19:39 - 19 Apr 2015    Post subject: Reply with quote
Apart from the air filters, they come ready primed Thumbs Up
Copycat73
PostPosted: 20:15 - 19 Apr 2015    Post subject: Reply with quote
you know that feelin that you forgot summit Wink
https://i867.photobucket.com/albums/ab232/copycat73/24k%20Service%2014th%20jan%202013/Photo0974_zpsfaf20949.jpg
caveat emptor
PostPosted: 20:46 - 19 Apr 2015    Post subject: Reply with quote
BMW ones, you have to go to a Motorrad and have them filled from cannisters of compressed Alpine air.
-Matt-
PostPosted: 21:21 - 19 Apr 2015    Post subject: Reply with quote
Always put a bit of oil on the seal but thats the first i've even heard of priming, so its a no from me Whistle.
Always just assumed it soaked into the filter as soon as I filled the oil back up Embarassed.
Out of interest what sort of things would make it wise to prime the filter, would it generally be older bikes?
Eddie Hitler
PostPosted: 22:43 - 19 Apr 2015    Post subject: Reply with quote
Always prime mine.
PostPosted: 22:51 - 19 Apr 2015    Post subject: Reply with quote
Kawasaki sports bikes, like the zx6/10r are prone to not self-priming, as an example. Many threads about it.
WD Forte
PostPosted: 01:24 - 20 Apr 2015    Post subject: Reply with quote
Or you can hold them to yer face whilst singing selections from the Sound of Music.
When I had my beemers I found that singing
"high on hill was a lonely goatherd" got them well primed
bikers smell of wee
covent.gardens
World Clap Champion
PostPosted: 09:28 - 20 Apr 2015    Post subject: Reply with quote
Depending on the angle of the filter I don't always put much oil in, but I always put some in, and smear the seal.
skatefreak
PostPosted: 09:43 - 20 Apr 2015    Post subject: Reply with quote
These small filters don't cause a problem and pretty much self prime.
When it comes to fitting a filter, a layer of fresh oil on the mating surface, clean the engine side and put on Hand Tight!
I've never had a leak on a car or bike and can always get them off by hand again without a tool!
Getting a new bike/car usually means putting a screwdriver through the filter to get it off... A lot messier!
-Jvr
Iain.
PostPosted: 10:31 - 20 Apr 2015    Post subject: Reply with quote
This concerns me, massively considering you're working with KTM's & certain models have a specific priming proceedure that includes injecting a set amount of oil into the headstock bleeder to fill the filter up prior to engine start. Shocked
Only after priming it can you then run the engine up, bleeding the air out of the same port before nipping it up, before confirming the correct oil level on the appropriate sight glass.
https://www.advrider.com/Wisdom/GuidetochangingtheoilonanLC4.pdf
Personally on a ZZR I wouldn't bother. Would smear oil on the O-ring, then fill it up & watch the oil light. If the light doesn't go off within a second of the engine catching I'd kill it & check for issues as it doesn't take much to cabbage an engine with oil starvation.
Nemo
PostPosted: 14:24 - 20 Apr 2015    Post subject: Reply with quote
That's something completely different, as far as conventional wet sump bikes go, I don't prime them. Obviously if there is a sequence you follow it.
But he's not talking about ktm's, he's talking about his zzr.
Not only that, but not all ktm's are the same, some of them you don't prime.
MarkJ
PostPosted: 15:04 - 20 Apr 2015    Post subject: Reply with quote
My car and the Sprint ST have a filter that points straight down, so I fill them to the top before fitting. Other bikes that have the filter sideways on I might pour a glob into it but not much as it'll just spill out when fitting anyway. If the bike's been stood for ages I'll spin it over with the coil packs disconnected to prime the engine. If it's in regular use I'll just start it up after changing the oil.
I always put oil on the o-ring.
Iain.
PostPosted: 15:50 - 20 Apr 2015    Post subject: Reply with quote
I beated you to it! Dance!
Tungtvann
PostPosted: 17:08 - 20 Apr 2015    Post subject: Reply with quote
We used to have to prime the Challenger 2 filters, but they were the size of pringles cans and there were quite a few...
The last post was made 11 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 118.23 Kb
