Abba stands, anyone got/used one?
Shaft
PostPosted: 22:40 - 20 Apr 2015    Post subject: Abba stands, anyone got/used one? Reply with quote
Even all
In my new found vocation as an MOT tester, there are obviously several things you need to check with the wheels in the air and lots of bikes with no main stand.
As I don't fancy leaning someone's pride and joy over on a potentially weak side stand, or putting a jack under an expensive or fragile exhaust/belly pan, I've been looking around at possible solutions.
Paddock stands are no good, so I'm looking at an Abba stand, which can be had as a set with all the various fittings.
It seems almost too easy to use to be true, so are they really as good as they appear?
Ed Case
PostPosted: 22:44 - 20 Apr 2015    Post subject: Reply with quote
I couldn't be without one with my ER6F. Can't even adjust the chain properly without it and all for the sake of not making provision for a centre stand. All bikes without centre stands suck !.
jrenoc
PostPosted: 22:49 - 20 Apr 2015    Post subject: Reply with quote
Highly recommended, I'm sure they do an MOT testers kit which has all the different adaptors
jrenoc
PostPosted: 22:54 - 20 Apr 2015    Post subject: Reply with quote
jrenoc
PostPosted: 22:59 - 20 Apr 2015    Post subject: Reply with quote
kawakid
PostPosted: 23:01 - 20 Apr 2015    Post subject: Reply with quote
Agreed I have an N and it's essential.
But as an MOT tester you will need lots of different inserts for every type of bike.
For example on the ER you need an adapter that goes over the swing arm nut. However on the Z the adapter goes in to the swing arm mount.
I've a twin and a 4.
Islander
PostPosted: 23:03 - 20 Apr 2015    Post subject: Reply with quote
I have one and swear by it - they're super stable and totally risk free. No balancing act required to put the bike on it.
Abba sell a mechanic's kit with all the adaptors which will probably be a good choice for you. Our local workshop uses several of them and has that very kit. Thumbs Up
Islander
PostPosted: 23:06 - 20 Apr 2015    Post subject: Reply with quote
Here you go:
Technicians kit:
https://abbastands.co.uk/product-detail.asp?item=technicians-kit&pid=13
Tecnicians kit with swing arm removal kit:
https://abbastands.co.uk/product-detail.asp?item=technicians-kit-inc-sark&pid=33
kramdra
PostPosted: 23:30 - 20 Apr 2015    Post subject: Reply with quote
Ive made a couple. While abbastands seem to do the job, the "need" for adaptors is a load of bollocks.
As a professional, you can probably justify a better bit of kit, there are a few options.
Shaft
PostPosted: 23:50 - 20 Apr 2015    Post subject: Reply with quote
What are the other options?
This is the one I would go for, seems to do everything I need it to and on the odd bike it won't fit, if I think there's a danger of damaging it, I can refuse to test.
https://abbastands.co.uk/product-detail.asp?item=pro-workshop-package&pid=37
kramdra
PostPosted: 00:41 - 21 Apr 2015    Post subject: Reply with quote
How much? Shocked I'd probably go with one of these (or the many variations) if I had workshop sized space, where it would be very nice to move shit around without wheels fitted. I'd have several Laughing
https://www.demon-tweeks.co.uk/Product.do?method=view&n=4553&p=387421
These are designed to sell adaptor kits for £££, it could easily be done/modified to be universal.
https://www.demon-tweeks.co.uk/motorcycle/bike-specific-stands-lifts/warrior-spider-stand-adapter
Going
PostPosted: 01:26 - 21 Apr 2015    Post subject: Reply with quote
The above seems good, if only I had the space Confused
I got an abba stand a few years ago, made life much easier to do stuff, trying not to lose the different pins is the hard part Smile
davebike
PostPosted: 09:07 - 21 Apr 2015    Post subject: Reply with quote
Abba stand and full kit of fittings is the way to go as a pro
Worth calling ABBA they may do you a better price than on web if you are REAL trade
I certainly got a great deal at EXPO a few years ago
Dave
NC750Xdct + others at work !
[email protected]
t121anf
PostPosted: 09:31 - 21 Apr 2015    Post subject: Reply with quote
This thread reminded me of the cool product Abba make, need to get a front arm lift kit ordered as the superbike front lift thing is useless.
Quite fancy a wheel spin to but it's discontinued, other brands are on ebay though.
Then there's the Skylift, if only I needed one.
Dcwhite1984
PostPosted: 09:44 - 21 Apr 2015    Post subject: Reply with quote
I've got an abba stand and yeah they are as easy to use as they make out.
Please as punch with mine currently my bike is without wheels held up by an abba stand and 2 axle stands under the forks, couldn't justify the extra £50 for the front lift arm for the limited use ill get from it, if i need the front wheel off the ground i use a jack under the exhaust with a plank of wood and then prop the front on the axle stands as above.
Just go for it, you will not regret it. Very Happy
The trick to life is to not get too attached to it.........
PostPosted: 10:23 - 21 Apr 2015    Post subject: Reply with quote
I've got one, it's awesome. Had it for years, well worth the cash. You do need adaptors for each bike, and they don't fit some bikes (like Buells for example). But they are dead easy to use and very versatile.
PostPosted: 10:25 - 21 Apr 2015    Post subject: Reply with quote
Something that I was casually pondering recently is: how do you lift a bike with no centre stand and a single sided swing arm? Is the only way with a platform lift (or some precarious balancing act) under the engine/frame and lifting until the rear wheel comes off the ground?
Fisty
PostPosted: 10:39 - 21 Apr 2015    Post subject: Reply with quote
On an abba stand
https://i768.photobucket.com/albums/xx326/tropical-penguin/Honda%20Vfr400%20KOSO%20rx1n%20Clocks%20Project/IMAG0440.jpg
Fatter and faster than Fret
PostPosted: 11:00 - 21 Apr 2015    Post subject: Reply with quote
Oh... sorcery!
OK, now I see the point.
DrSnoosnoo
PostPosted: 11:10 - 21 Apr 2015    Post subject: Reply with quote
I have now decided I need one. I have a centrestand but, abba is so much better!
PostPosted: 11:35 - 21 Apr 2015    Post subject: Reply with quote
They really are cracking bits of kit but as well as a centre stand Laughing
Carvel
PostPosted: 12:07 - 21 Apr 2015    Post subject: Reply with quote
Yep, Abba stands are mega. Easy to use and super stable.
https://i979.photobucket.com/albums/ae271/RxsOllie/IMG_1886_zpsxu8zsqcs.jpg~original
Same adaptors fit my NC30 and Cbr600 which is a bonus, neither of which have centrestands making the abba stand essential.
Doovy
PostPosted: 12:14 - 21 Apr 2015    Post subject: Reply with quote
Nice K.A Thumbs Up
Fowlersrs
PostPosted: 13:06 - 21 Apr 2015    Post subject: Reply with quote
Wouldn't be without mine. It makes lifting the rear so easy with the extending arm, it's also pretty rock solid once it's up.
Snorty
PostPosted: 13:26 - 21 Apr 2015    Post subject: Reply with quote
Great stand. Made it easy to service rear suspension. I have the swingarm removal adapters as well. So much easier to use on your own than a usual paddock stand.
The last post was made 11 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 129.55 Kb
