| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 00:07 - 21 Apr 2015 Post subject: Side Panel Repair/Bodgery? |
I need to repair the side panels on my project bike, (Xl125RC), the problem being the plastic lugs, which plug into the frame, holding the panels in place, have snapped off at some point. I am only missing the front lug, the rear is good and the bottom of the panel is bolted to the frame. These are the soft plastic type panels.
The lugs are not available so I can't glue or plastic weld them back on.
I currently have a couple of bodgetastic ideas to save buying more panels.
Idea 1.
Fix a rubber type block to the frame lug and glue velcro to the block and the back of the side panel.
I imagine the drawback with this is that the velcro and the glue will need replacing on a regular basis.
Idea 2.
Drill a hole in the panel and bolt it in place or use Dzuz type fastners.
The draw back with this is, where the bolt/fastner head will be, will no doubt be right where my legs catch the panel.
Idea 3
Ghetto solution, drill a small hole in the top/side of the panel and cable tie it to the frame!
Whaddya think then, anyone been down either of these routes, or do you have better solutions? ____________________ "Everybody needs money, that's why they call it money!"  |
| SQL |
 SQL World Chat Champion
| Val |
 Val World Chat Champion
 Posted: 02:18 - 21 Apr 2015 Post subject: |
Delboy uses cable tie to weld fix the lug:
https://www.youtube.com/watch?v=k7GRNvPSf7k ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 08:12 - 21 Apr 2015 Post subject: |
Check to see if your local tech college has a 3D Printer, and ask if they will build-up some new lugs as a student project. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Matt B |
 Matt B World Chat Champion
 Posted: 10:09 - 21 Apr 2015 Post subject: |
Can you not attach something like this to the back of the panel so it can still push into the grommet hole thing? Or bend one up to the right size out of a bit of strip metal.
https://i.ebayimg.com/00/s/ODAwWDgwMA==/z/7Z8AAOxy3zNSmdAj/$_57.JPG ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 11:04 - 21 Apr 2015 Post subject: |
3D printing sounds like a plan
There's a Hackspace here in Bristol where a few of the folk have 3D printers and i just checked and see there's one in Nottingham.
This may not be too far for you to drop in and ask for a favour.
Most printers use ABS ( strimmer wire) and providing you can bond this the panel, you may get good results
Pitchers would really help of course to get an idea of shape and dimensions,
but I've sometimes nipped to local shops to get a cheap, thick, plastic cutting board to carve things out of.
Edit found the project posts in S/A/T
https://www.bikechatforums.com/viewtopic.php?t=278824
No pics of upper insides of panels to see good/bad lugs ____________________ bikers smell of wee |
| Suntan Sid |
 Posted: 12:16 - 21 Apr 2015 Post subject: |
Thanks for the replies.
My problem with replacing the, push fit, lug is I don't have the original, so I've got nothing work with or to base a homemade one on. Also the PO has removed all traces of the broken, original lug.
In Del boys video the panels he's repairing are not the same type of plastic I've got, mine are the motox type, soft, bendy stuff, does that make a difference? ____________________ "Everybody needs money, that's why they call it money!"  |
| bikenut |
 bikenut World Chat Champion
| stirlinggaz |
 stirlinggaz World Chat Champion
| bugeye_bob |
 bugeye_bob World Chat Champion
 Posted: 17:37 - 21 Apr 2015 Post subject: |
what about a pipe clip, if you get the correct size it will just hold the corner secure to the frame, also wont require any special tools when you come to remove it again,
It may need a small bracket on the rear of the panel so the side panel is still level
https://www.gasproducts.co.uk/acatalog/ha868.jpg |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Hop Along Biker |
 Hop Along Biker L Plate Warrior
The last post was made 10 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
