| smithyithy |
 smithyithy Spanner Monkey
 Posted: 19:53 - 22 Apr 2015 Post subject: Non-starter - Triumph Daytona 675R |
Hi guys, bit of a problem hopefully someone can help with..
Odd one.. Have't ridden much in a while as the weather has only recently picked up. Bike has been on almost constant trickle charge though and the few times I've took it out, it's started first time and been fine.
Came to take it to work this morning to no avail. The ignition and lights turn on, fuel pump etc. But it won't crank.
I press the starter and it 'pings' once then the dash lights 'turn over' as below:
https://farm6.staticflickr.com/5460/16616775913_8e2f1b57f8_o.gif
We managed to bump start it down my road, it fired up straight away, I looped around the road and back onto my drive, left it running but it was hesitating slightly then after about 30 seconds died.
I borrowed a multimeter and checked the battery after it cut out and it was reading 10.4 volts..
I reconnected the trickle charger and this also confirmed 10.4 - 10.5 volts, but once it started charging it went back up to 12.8 volts..
Could it just be a case of the battery needing replacing?
| G |
 G The Voice of Reason
| smithyithy |
 Posted: 20:08 - 22 Apr 2015 Post subject: |
Sound, will do  |
| andys675 |
 andys675 World Chat Champion
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 21:21 - 22 Apr 2015 Post subject: |
| andys675 wrote: | yes battery, b'stard dealers don't charge them properly when new so they never work their full potential, mine went 18 months, crap service for a yuasa but not triumph or yuasa's fault, made sure the the new one was properly charged before fitting |
Totally agree.
I don't work in PDI, but I do know that triumph give all the dealers very clear instructions on how to prepare the battery (not hard in the first place), yet they still don't follow them.
Probably because they leave everything to the last minute then rush everything. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| G |
| Nemo |
| andys675 |
| G |
| smithyithy |
| cheeseman |
 cheeseman Trackday Trickster
| andys675 |
| smithyithy |
 Posted: 22:34 - 12 May 2015 Post subject: |
New battery fitted, everything's sweet.
Cheers guys  |
The last post was made 11 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
