RF600 - Rideable, MOT'd £500
Iain.
PostPosted: 14:06 - 23 Apr 2015    Post subject: RF600 - Rideable, MOT'd £500 Reply with quote
https://i.imgur.com/8ElDgCUl.jpg
https://i.imgur.com/gwAjGWQl.jpg
'93 RF600
Good
    Has nearly a full years MOT.
    Meat on both tyres
    Chain & Sprockets in reasonable condition
    Recent service - Oil filter, air filter, plugs, fresh coolant and fresh oil
    Pulled happily up to 130-135mph, so the engines clearly okay.
    Brakes were stripped & cleaned, then filled with fresh fluid.
Bad
    Advisory on MOT for front wheel bearing.
    Speedo drive clicks, but speedo works perfectly well.
    Downpipes are blowing very badly, I made a patch out of tinfoil and gun gum to get it through MOT which seemed to hold for a few months. I have set of downpipes to go with the bike, however they are off a late model so you need to find a late model sump to fit them. I also have all the required gaskets to fit the exhaust to go with it.
    Fork seal one side is a little bit weepy, happened after the Southend Shakedown...I'd assume I hit a pothole a bit hard.
    Has some bizzare fuelling issue which I suspect to be muck in the carbs. They'll be stripped, cleaned and re-balanced prior to sale.
Ugly
    It's an RF & thus not very pretty
    Theres scratches and marks on every panel
    It has purple wheels
    Some stickers are peeling off
    The fairing bolts are a mismatch of OEM and chinese pattern parts
Reason for sale
https://i.imgur.com/WFLymed.gif
Fuelling issue caused it to cut out, it's cost me £200 to recover the fecking thing, I'm skint & I'm particularily pissed off with it at the moment.
In its defence it did fire straight back up in the recovery yard, and did the Southend Shakedown with no issues & wasn't a bad bike to ride, but the sight of it makes me want to set it on fire at the moment.
The last post was made 11 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 29.9 Kb
