Engine braking
UncleFester
PostPosted: 21:20 - 23 Apr 2015    Post subject: Engine braking Reply with quote
So i've been hacking 80 miles a day to work on back for the last 6 weeks on the CB500 and it's pretty clear there is plenty of engine braking. What i don't know ( being a n00b) and am interested in finding out is what other bikes are like in this regard.
I know an IL4 won't have anywhere near as much and i'd have to adjust my riding style but what about stuff like Triumph Street Triple - do these offer something similar to the CB500?
I do like being able to roll off the throttle and lose speeed ... equally it's nice to just close the throttle and have it clatter and bang out of the exhaust but that's just me being a noisy git Mr. Green
Is engine braking just a lazy way of avoiding to learn to brake properly or is it genuinely a handy tool to ride with.
2017 Z1000SX
robertw95
PostPosted: 21:23 - 23 Apr 2015    Post subject: Reply with quote
I found the daytona 675 to have pretty similar engine braking to my sv, if out on a spirited run I often find myself not touching brakes for miles on end setting speed up purely on engine braking aslongs there is no cars behind
07 Dt125r, sv650s k8, zx6rr 04
robertw95
PostPosted: 21:24 - 23 Apr 2015    Post subject: Reply with quote
UncleFester
PostPosted: 21:31 - 23 Apr 2015    Post subject: Reply with quote
That's what i've been doing and just focussing on moving along smoothly .... only have to use the brakes for approaching roundabouts or in heavy stop start traffic - the rest of the time i just moderate the speed using the clutch / gears. Quite happy and able to get quickly and fairly smoothly up to speed but it just feels natural to shed the speed without using the brakes unless I have to.
I realise this is not a sports bike approach to riding ... but then i'm really not that kind of biker.
I've also got one eye on the next bike ..... but still love the way the twin gives its power.
2017 Z1000SX
orac
PostPosted: 21:43 - 23 Apr 2015    Post subject: Reply with quote
10 mile to work and the brakes only get used on the a downhill section where I need to turn into a junction and at 3 set of light, unless I am having a spirited ride to or from work. and thats on a IL4. the gs5 was did have stronger hold back so you could back off a little later, however any difference is negated by the fact the little 400 is quicker through and out of the bends. it all depends on how you ride.
a buddy rides ducs and reckons the engine braking on them is pretty strong.
PostPosted: 21:51 - 23 Apr 2015    Post subject: Re: Engine braking Reply with quote
How do you 'know' that?
Not my experience.
I'd say when racing the R6 had more engine braking than the bigger capacity SV650.
However, people tend to be at a lower point in the revrange on a four cylinder bike on the road.
Engine braking is 'for' knocking it down a couple of gears to get the back going sideways into a turn. Learn to use the brakes properly to keep it going Smile.
Supermoto_Fan
PostPosted: 22:04 - 23 Apr 2015    Post subject: Reply with quote
Chopping the throttle on my SV propels your nuts into the tank. Immense engine breaking from the V twin dropping a cog whilst up in tbe 5 - 6k area.
*probably made worse by tbe poor suspension both front and rear and tbe loud exhaust.
robertw95
PostPosted: 22:20 - 23 Apr 2015    Post subject: Reply with quote
I also agree much stronger braking on sv compared to my 636
Albigularis
PostPosted: 22:26 - 23 Apr 2015    Post subject: Reply with quote
In general, more cylinders = less engine braking. Parallel twin engine braking seems to be much more severe on the ER5/6 that I've tried than any other bike I've ever been on. The BMW twin cylinder boxer engines have very little engine braking, at 3k rpm on a cold engine it almost has cruise control if you just let go.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
bikertomm
PostPosted: 22:28 - 23 Apr 2015    Post subject: Re: Engine braking Reply with quote
What G said. Plenty of engine braking on my Hornet!
Pigeon
PostPosted: 22:51 - 23 Apr 2015    Post subject: Reply with quote
I didn't find that. SV is a natural handbrake in comparison.
If I go from the SV to the ST after riding the SV for a long time, I find I'm barrelling into corners waaay faster because the rolloff is so gradual in comparison.
In fact, I remember reading somewhere something about the ST having some sensor that slows the fuel cutout on a shut throttle. So it deliberately doesn't engine brake so much......did a quick google, cant find it though.
lynnnsr
PostPosted: 22:54 - 23 Apr 2015    Post subject: Reply with quote
Barely need the brakes if I plan ahead enough on my NTV (V-twin) - engine braking is often enough
NSR 125 (with L-Plates) > 1994 NTV 650 > 2015 CB650F > 16 VFR800F
PostPosted: 23:06 - 23 Apr 2015    Post subject: Reply with quote
Do you go in at a similar percentage of revs? Ie 2/3rds revs on both bikes?
kramdra
PostPosted: 23:07 - 23 Apr 2015    Post subject: Reply with quote
IL4 gets similar engine braking at high RPM as more friction. Twins make more vacuum at low rpm.
IL4 sports also go faster than commuter twins, so there is the benefit of high speed drag. Sitting up while shutting the throttle at 140mph, with a large topbox fitted is quite interesting Laughing
UncleFester
PostPosted: 23:12 - 23 Apr 2015    Post subject: Reply with quote
I also wonder how much of this is subjective and relative to experience?
A world where 14k rpm is possible exists in a different dimension at the moment and the point where my skill would be able to utilise it is sat right next to it.
2017 Z1000SX
talkToTheHat
PostPosted: 23:14 - 23 Apr 2015    Post subject: Reply with quote
I can ride my 535 on nearly idle and it will cruise leisurely... And fart and go nowhere if I grab a fistful of throttle. Or I can ride it like one is supposed to, keeping it in the upper half of the rev range, and the throttle works both ways to control my speed reasonably precisely, complete with a good dose of crackle and pop, particularly descending a hill in second gear, keeping a constant 30 without touching the brakes. Will put my balls in the tank and unsettle the rear end if I'm properly hamfisted with the downshifts.
Engine braking and regular brakes is tricky to the point where under hard braking I train myself to lose the speed with brakes and *then* shift down so my emergency brake reaction has less to juggle. There's no point engine braking and having to concentrate on modulating clutch, throttle and rear brake so as not to lock the rear when my rear brake is significantly smoother. It's a case of being ble to pick the stratergy that works, but being able to use engine braking is part of being in a responsive gear, which is sensible and safe and what you should be doing.
I had the luxury of riding most of snake pass eastbound when I did my bikesafe with the instructions of avoid using my brakes unless I felt I needed to. Used them at traffic lights midway and to slow for a corner after a brisk overtake and otherwise was an exercise in throttle control. Fuel economy significantly improved.
Bandit. does. everything.
Pigeon
PostPosted: 23:20 - 23 Apr 2015    Post subject: Reply with quote
If I'm honest, possibly not, I may well be going on engine note and gear. The ST's higher pitch does (when not used for 6 weeks like recently) trick me into shifting earlier compared to SV.
I'm probably in too tall a gear on the ST for the same bend.
Cornering fine in 4th on the SV at around 6krpm, is probably 3rd on the ST at the same speed. So coming in at 4th at 5k is what I'm doing possibly.
I know riding the SV I don't tend to bother with brakes unless feeling a little frisky.
robertw95
PostPosted: 23:31 - 23 Apr 2015    Post subject: Reply with quote
The Daytona engines are slightly different I beleive so maybe that's why I also only got about 15 mins on it but defenitely had good engine braking a bit less than the sv but not by much
The last post was made 11 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 100.14 Kb
