Suzuki GSR 600 need help
xr_blackskins
PostPosted: 05:08 - 25 Apr 2015    Post subject: Suzuki GSR 600 need help Reply with quote
Hi all,
I have owned a Suzuki GSR 600 2007 since 2010.
recently, a problem happened to my bike.
the FI flashing whenever the engine rotation reaches 8000 rpm and the bike runs abnormally (shake). when I turned off the ignition key and restart, the FI light went out
Please give me your advice on what happens to my bike and how to fix the problem.
many thanks,
Nguyen
iooi
PostPosted: 06:06 - 25 Apr 2015    Post subject: Reply with quote
The Workshop
Technical discussions and mechanical advice. Need help with your bike?
PostPosted: 06:44 - 25 Apr 2015    Post subject: Reply with quote
Yeah, workshop.
Anyway, find the dealermode connector, it's a small connector block near the fusebox with a cap on it. The connector should have a white/red wire and a black/white wire.
When you get a fault, stop riding, kill the engine but leave the ignition turned on. Use a paperclip to short the two wires in that connector and you'll get a code on the dashboard. That code will tell you where the fault is.
When you turn off the ignition, all codes are cleared so you have to do all of the above with the key turned on or you're wasting your time.
gummer
PostPosted: 22:55 - 25 Apr 2015    Post subject: Reply with quote
My k1 did this, caused by an after market alarm. Removed alarm had no problems since
The last post was made 11 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 39.52 Kb
