U Turns
kev98
PostPosted: 15:21 - 31 Jan 2005    Post subject: U Turns Reply with quote
Im about to take my test in a couple of weeks time and was wondering what size road you have to do the u turn on. eg 2 car width or 3 car etc
Thanks
Quote Me Happy
PostPosted: 15:26 - 31 Jan 2005    Post subject: Reply with quote
It's about 3 car widths. Don't worry the examiner will be doing it somewhere where hundreds of people will have already done it on their tests. As long as you have your slow control mastered then you'll be fine. Good luck Thumbs Up
cc123
Geez a joab?
PostPosted: 16:25 - 31 Jan 2005    Post subject: Reply with quote
The road is only tight as you make it.
I dropped the bike twice when I was learning on a very tight sloping street. Guess the instructors thought if we could U-turn there, we could do it anywhere...
Always look where your turning, it's the key. Look at the kerb and you WILL hit it !
Old bikes >>> https://www.bikepics.com/members/cc123/
White Noise
Mr Dudwee
PostPosted: 22:16 - 31 Jan 2005    Post subject: Reply with quote
By the way what are you learning on, if its something light like a 125 you could have a go at this.
i hired a CG out on sunday and got a bit bored, so i found a deserted piece of tarmac and see how many times i could carry on going round in circles, (i.e do a U'ey an keep on turning) well i ended up doing so much and getting it to full lock i got dizzy and nearly fell off, tried doing a U'ey after and got it round so easy, just keep you head up and look to where you want to go. Clutch control is everything!
Hope it helps
WN
Knisis
PostPosted: 21:15 - 01 Feb 2005    Post subject: Reply with quote
Today on my DAS course I had to do a u-turn. The road used was the same width as my test will be on. I managed to use just 75% of the width Smile
My instructor told me, on the test the tester will ask you to walk the bike around the road. Important: Make sure you do a rear observation before walking around, apparently someone failed cos they walked around as a car came along.
Make sure when you pull up to give yourself plenty of space to any cars in front, if not roll bike back before riding a u-turn.
And as many have said, Rear observation, Clutch and back break only, roll foward parrallel to the road, life saver, turn and look down the road. "Where you look is where you go"
Good luck
The last post was made 21 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 44.07 Kb
