Re Threading - Helicoil - stripped threads etc.
PostPosted: 15:02 - 31 Jan 2005    Post subject: Re Threading - Helicoil - stripped threads etc. Reply with quote
Hi people,
I have a bit of an *ahem* issue with my TT600. I believe that I *may* have stripped the thread out of the cylinder head when fitting my crash mushrooms...
I know it is easy to do, and I saw some bits of swarf come out of the hole when I removed the bolt again. The bolt still screws in correctly, and I didn't put a lot of pressure on it in the first place. Admittedly I didn't use a torque wrench, but I was just doing it up carefully with an ordinary ratchet. I can't see how I sripped the thread, and in the workshop manual it says to use threadlock on the bolt. I am hoping that the bits on my garage floor I took to be swarf were in fact old threadlock...
My questions are thus:
Arrow How can I be sure I stripped the thread?
Arrow How difficult is putting in a thread repair such as a Helicoil?
Arrow I take it I will have to remove the engine from the frame? Arrow
Arrow How do I find out what pitch the thread needs to be on the Helicoil?
Please Help!
cagiva gezzer
PostPosted: 16:15 - 31 Jan 2005    Post subject: Reply with quote
When i manage to strip threads there are always bits of curly maetal pubes that come out if you stick a thin screwdriver in the hole.
I get the mechanics from my dad's engineering firm to recoil my bits, but they do it in a few minutes.
To select the correct insert you just try threading the inserts onto the old bolt.
kasandrich
PostPosted: 16:47 - 31 Jan 2005    Post subject: Reply with quote
The question is, does your mushroom do up tight OK now, or does it just keep turning?
If it does up OK now, you are probably OK
Richard
CBR1000FM
Robby
Dirty Old Man
PostPosted: 17:39 - 31 Jan 2005    Post subject: Reply with quote
I'd just screw the mushroom back in, gently, and see how it feels on the way in. If its a bit rough, try the stinkwheel technique of turning half a turn, backing off a quarter, turning another half turn and so on.
If you have buggered the thread you need to drill out the old thread and a bit more to fit a helicoil anyway, so be utterly sure its knackered.
PostPosted: 20:59 - 31 Jan 2005    Post subject: Reply with quote
It screws in fine, I'm just scared to see if it will go tight. I can do it up and I can't pull it out just by pulling, but it never seems to want to stop turning. That might just be because I'm scared to tighten it now... Confused
THe torque setting in the workshop manual says 40nm. Is that a lot?
Help!
cagiva gezzer
PostPosted: 21:15 - 31 Jan 2005    Post subject: Reply with quote
Just a thought. Are these mushrooms 100% nylon? If so, they will compress as you tighten them and you'll have to compress them a lot until you reach the same torque as stated in the manual.
Do the mushrooms come with instructions?
PostPosted: 21:30 - 31 Jan 2005    Post subject: Reply with quote
Yes but they don't have torque settings in the 'shroom instructions and they have steel centres in the nylon parts.
They are R and G mushrooms...
loply
PostPosted: 23:03 - 31 Jan 2005    Post subject: Reply with quote
40nm is not a lot. The nut on the rear axle will probably be 100nm or so.
But its imposibble to describe how much 40nm is, you need a torque wrench
Yamaha SZR660 Caution to the wind, the throttle pinned!
cagiva gezzer
PostPosted: 23:19 - 31 Jan 2005    Post subject: Reply with quote
40nm is very tight. The highest settings on mine are ~50Nm for the front wheel, ~70Nm for the rear wheel and ~75Nm for the rotor/magneto and that takes a good shove with a large wrench.
PostPosted: 23:52 - 31 Jan 2005    Post subject: Reply with quote
Well the R and G instructions say tighten it until you feel some resistance then tighten another quarter turn - which is exactly what I have done.
The mushroom is solid and I can't remove the bolt without a socket.
I might bung some liquid threadlock on there to be on the safe side.
PostPosted: 00:40 - 01 Feb 2005    Post subject: Reply with quote
Is this just the 'bolt' that goes in, or the nut on top?
The ones I've have had have had a threaded rod at both ends. You screw the rod into the mount, then slip the bung on and do up a bolt on the second thread.
It's this second bolt that has to be tensioned I suspect.
PostPosted: 14:17 - 01 Feb 2005    Post subject: Reply with quote
Its a one piece bolt that goes through the nylon part (which has a steel sleeve) and then it has an alloy spacer. This assembly all hangs off the bolt which screws into the cylinder head through the frame.
The last post was made 21 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 75.83 Kb
