Keeping a bike outside....
Where do your bikes live?
Garrage are you mad?! in my house where it should be!
0%
 0%  [ 0 ]
In the garrage, away from the elements..
52%
 52%  [ 13 ]
Outside but well out of sight.
28%
 28%  [ 7 ]
On the street, cover on, lamp-post jobby.
8%
 8%  [ 2 ]
none of the above...
12%
 12%  [ 3 ]
Total Votes : 25
mr.z
PostPosted: 03:04 - 01 Feb 2005    Post subject: Keeping a bike outside.... Reply with quote
Being the jammy git i am, my bike is currently monopolizing the garage (despite many threats for the fiesta to be put back, shareing the space) so my ta is ok...
But, sometime in the near future i'll be getting my hands on a 70's (76 i think) model cg125 (3000miles on it! Shocked ), needs a few things doing to it, mainly a bit of a cleaning Very Happy will probably finish up doing a full restoration eventually...
Thing is it will possibly have to live outside, probably used every month or so (maybe more maybe less, not 100% sure) behind 2 locked doors and under a cover maybe two..
Generally i'll allways cover my bikes in wd40 as weather protection anyway, lots o'grease in the right places... but is there anything else that i'd need to be carefull of if its going to be liveing outside?
Woo, finaly got myself a project to play with though Thumbs Up (sorry in advance for posts in workshop Razz )
binge
Emo Kiddy
PostPosted: 04:03 - 01 Feb 2005    Post subject: Reply with quote
If the air intake is quite exposed, Get a small bag and elastic band, and put it over the airbox/carb as the damp can sometimes stop it from starting (I have this problem and its kept in the garage Shocked )
erm, are you intending to get a ground anchor? I recomend it!
<|Binge|>
bish777
PostPosted: 09:21 - 01 Feb 2005    Post subject: Reply with quote
Buy some ignition sealer spray and COAT you HT leads in loads of the stuff, also coat the joins to the coils (with the leads in place) so it seals the joins, and also (with the caps in place on the plugs on the leads and covers all in place) coat the caps.
Dont go mad with WD40 in the lectrics as it can cause shorts.
Further to what binge has said, if the bike wont start, turn fuel tap off, drain the float bowls, turn the tap back on and let it refill. Its probably water in the float bowls- assuming you've sealed the ignition system.
Whilst your at it, seal the points compartment on the crank case with instant gasket rather than a honda paper gasket as it prevents moisture getting into the points much better!
ZaphodBeeble
PostPosted: 09:38 - 01 Feb 2005    Post subject: Reply with quote
Me and my brother usually lock the bikes to a lamppost and each other. But I have the option of keeping my bike in a garage about 2 miles from my house. I only do that if I'm not going to be riding for a few days. As it is I'm riding quite often so I keep it 'ready-to-go' outside. Mr. Green
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
cc123
Geez a joab?
PostPosted: 09:51 - 01 Feb 2005    Post subject: Reply with quote
I keep mines garaged 15 miles from my house!! At my mates house, also chained to his 2 other bikes all alarmed tagged the lot... Very Happy
Someone steals or trys to steal it I'll break there neck. Evil or Very Mad
Also, garaged stops it from rotting. My car can rot all it likes!! Laughing
Old bikes >>> https://www.bikepics.com/members/cc123/
map
Mr Calendar
PostPosted: 09:53 - 01 Feb 2005    Post subject: Re: Keeping a bike outside.... Reply with quote
zero wrote:
...getting my hands on a 70's (76 i think) model cg125...
Needs to be in the garage and locked away. I can pick up a CG125 to move it around. There are guys out there who could easily put it under their arm and walk off with it Very Happy
yambabe
PostPosted: 14:09 - 01 Feb 2005    Post subject: Reply with quote
I would agree with Map. If you're not going to be using it regularly, keep it shut away or at least fastened securely.
My "project" bikes live in the garage, my day-to-day ride lives with them in the winter (with just occasional trips out) and on the patio in the summer.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 15 - Page Size: 58.83 Kb
