Boeing 787 bug could cause 'loss of control'
ScaredyCat
PostPosted: 14:48 - 02 May 2015    Post subject: Boeing 787 bug could cause 'loss of control' Reply with quote
https://www.theguardian.com/business/2015/may/01/us-aviation-authority-boeing-787-dreamliner-bug-could-cause-loss-of-control
The plane’s electrical generators fall into a failsafe mode if kept continuously powered on for 248 days. The 787 has four such main generator-control units that, if powered on at the same time, could fail simultaneously and cause a complete electrical shutdown.
32 bit signed timer : 248.551 days = 2^31 x 10 ms
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 14:55 - 02 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
I would wonder why they used a signed integer. Or do they expect the plane to go back in time.
K
ScaredyCat
PostPosted: 15:03 - 02 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
The fix is even funnier, turn it off and back on again.
PostPosted: 16:06 - 02 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
Because "int" is 3 characters and you can't teach responsibility.
When I worked in the nuke industry, we printed off the entire source code of the final delivery and every single line was individually reviewed and personally initialled by the lead engineer (real, chartered). In red.
Ask not if can you afford to do that, but if you can afford not to do it.
PostPosted: 18:44 - 02 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
Checking lines isn't the problem. It is how those lines affect each individual other line that is likely to be the problem
K
The Wobbly Orange
PostPosted: 19:21 - 02 May 2015    Post subject: Reply with quote
One would have thought there would be scheduled maintenance more often than 248 days.
People tell me I am lovely. How wrong they are!
PostPosted: 21:09 - 02 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
Making it one specific, named individual's problem did seem to bring that <you-dont-say.png> issue into sharp focus though.
If you, personally, had to put your career on the line over a delivery, no hiding behind a contract or a company or limited liability, if you were saying "I vouch for this system," would you up your game?
The chap who initialled our code didn't take "Yeah, probably," as an answer.
PostPosted: 22:31 - 02 May 2015    Post subject: Reply with quote
That is a hope, but unless it is a fairly noddy system the chances of one person being able to actually understand it well enough for their signature to be meaningful is pretty low.
K
PostPosted: 23:38 - 02 May 2015    Post subject: Reply with quote
Hunterston B doesn't go into meltdown every 248.551 days, so I'd venture to suggest there's some merit in it.
Actually, that was the backup to the backup rod drop logger, which was only done to sloppy PES 1 standards, allowing for one failure every 10 years.
On the other hand, that company did go titsup, I suspect largely due to punking out on deliveries because they ran out of red pens.
The Wobbly Orange
PostPosted: 15:26 - 04 May 2015    Post subject: Reply with quote
Well I maintain aircraft for a living. Not 787's I'll grant you. We have systems on our aircraft that can't run continuously. Seems to me this is far more easily solved with a simple maintenance operation than a system redesign.
Item Task 22L to be complied with (cycling the electrical generators. Calender periodicity 90 days to allow for deferment.) or some such thing.
hmmmnz
PostPosted: 23:35 - 05 May 2015    Post subject: Reply with quote
the guardian is such a stupid paper almost as bad as the mail,
"could cause a crash"
any thing "could" cause a crash .
pilot eats bad chicken-spews into electrics boom plane falls out of the sky,
some one trips on a piece of badly laid carpet and uses the door release handle to stop their fall which didnt have the safety connected, door opens, everybody gets sucked out, boom plane crashes.
snakes escape from the hold and try to eat every one, boom plane crashes.
the humans are dead
I kick arse for the lord
PostPosted: 23:23 - 06 May 2015    Post subject: Reply with quote
Only a dodgy recording system so doubt anyone cares too much if it fails.
Probably good it is such a redundant system with such a worthless testing system. Probably kept the PHB happy though
K
Rowey
PostPosted: 01:27 - 07 May 2015    Post subject: Reply with quote
I've been working with 787's for a little while now, and I'll be plesently supprised if you don't have to down power the aircraft at least once a fortnight for some silly fault.
ZX6R C6F.
Llama-Farmer
PostPosted: 02:58 - 07 May 2015    Post subject: Reply with quote
Never heard of any aircraft which had GCUs powered continuously for that long anyway.
It's a non-issue, but a non-issue that shouldn't really be there anyway.
There's far worse things with aircraft going on that people don't know about (and don't need to know about) than something like this which isn't a real problem anyway.
It's like the tanks will run out of fuel if they're not filled up, not really an issue because they do get filled up... usually... with the correct metric/imperial units.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 12:30 - 08 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
Why the downgrade? Shifty
I sense awesome story/Kim Jong
PostPosted: 13:26 - 08 May 2015    Post subject: Re: Boeing 787 bug could cause 'loss of control' Reply with quote
Nope, it really was just that they made crazy, unreasonable demands that systems should actually work, while only paying government prices - and not "the Minister for Energy is about to take up a Directorship at PreferredBidderCorp" prices.
Well, they did then. For all I know now, they could be running on iPads and pulling down nightly fixes from the App Store.
The last post was made 11 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 97.59 Kb
