Squeally drum brake
talkToTheHat
PostPosted: 01:28 - 09 May 2015    Post subject: Squeally drum brake Reply with quote
The drum brake on the rear of my 535 has started squealing during slow ride conditions. It's fine fully off or if I use the brake hard, but just a touch makes all the brake squeal imaginable. Is this within normal operating parameters or do I need to get it looked at.
I had the brake shoes changed for EBCs last time I had tyres done, between 2k and 3k ago.
Bandit. does. everything.
Major Doss
PostPosted: 01:49 - 09 May 2015    Post subject: Reply with quote
Is there any play (or even a bit of fresh brake friendly ((graphite?)) lubricant) in the brake cam lever?
Copycat73
PostPosted: 06:51 - 09 May 2015    Post subject: Reply with quote
when we bought her xv535 the back brake would grab very harshly or squeal at speed.... basically it was full of crud.. mostly rust but also some brake dust...
I removed the wheel wit the brake assembly..
Emery clothed the inside of the brake drum and the surface of the shoes to remove any glaze...
Then poured boilin water and a little squeezy and scrubbed wit a new toilet brush ...
The pivot actuator needed a greesin aswell..you can check this for play at this point ..
re-assembled and problem sorted..
tl.dr. non expensive job but takes time and some skill.
caveat emptor
bikenut
PostPosted: 11:32 - 09 May 2015    Post subject: squeeeeeck Reply with quote
maybe time for a dee dust.......
remove the sharp edges from the brake shoe sides........and are they fully bedded in yet?? pics before any fettling....
you said you had the shoes changes...so you didn't do it??
nuts about bikes
talkToTheHat
PostPosted: 11:35 - 09 May 2015    Post subject: Reply with quote
It's quiet at speed, it's not grabby, it's just when I'm only just applying the rear brake it bursts into song.
No, I don't think there's any lube on the cam.
Tempted to investigate this myself.
Copycat, how did you lift he 535 to get access to the rear wheel?
bikenut
PostPosted: 11:42 - 09 May 2015    Post subject: bike Reply with quote
me thinks you should get a manual, and see the exploded views on cmnsl which may help you...........or take it back to the garage and pay them to do it......brakes are safety critical and your not sure how to take the back wheel out, so........
nuts about bikes
Major Doss
PostPosted: 12:35 - 09 May 2015    Post subject: Reply with quote
When I said cam, I really meant cam lever. My bad. Specifically the portion that passes through the backplate. But yeah, dedusting as said, would be good.
Islander
PostPosted: 12:46 - 09 May 2015    Post subject: Reply with quote
Before you get too deeply involved in complcated solutions, try removing the wheel and cleaning the dust out of the drum.
Copycat73
PostPosted: 13:26 - 09 May 2015    Post subject: Reply with quote
strung it up to the load bearing beams on the garage roof usin ratchet restraints .. does away wit all the risks and technical problems of a high lift ... Thumbs Up
Islander wrote:
Before you get too deeply involved in complicated solutions, try removing the wheel and cleaning the dust out of the drum.
removing the rear wheel on one of these things was the most complicated part of the operation.
caveat emptor
Copycat73
PostPosted: 13:31 - 09 May 2015    Post subject: Reply with quote
Vincent wrote:
.......and then rough up the shoes with some course glass paper Thumbs Up
if your gonna use glass paper make sure you wash the shoes properly afterwards... Thumbs Up
caveat emptor
talkToTheHat
PostPosted: 23:05 - 09 May 2015    Post subject: Reply with quote
I've had the back wheel out before. I know how it comes out. What I don't have right now is access to useful things like a proper bike table, which with some wooden props under the engine and some ratchet straps will lift a 535 quite stabily. Then it's undo the torque arm and brake linkage, undo the pinch bolt, then the spindle nut, the spindle comes out, catch the spacer before it gets lost, and the wheel comes out. Simples.
The problem boils down to the bike is a bastard to lift and I won't do that on my own so before I fuck about calling in favours to lift it, or pay a shop to fiddle with it, I might as well work out whether a bit of squeal is a problem.
Major Doss
PostPosted: 02:33 - 10 May 2015    Post subject: Reply with quote
Ok. I am pissed again.
OT. Ask advice, get advice, and then baww? Am i following the topic? Do it, get a shop to do it, or live with it.
Anyroadup.
Scissor jack will help you prop it up. You can use this jack forever, they are cool.
Admittedly, these are git bikes to deal with the rear end; pull the shocks- back end will drop enough to pull spindle/wheel.
Undust. Clever people said 'do this'. Dumb cunts like me only jump in to state the fucking obvious!
Clean with brake cleaner, small smear of grease on the lever as it passes through the backplate. Check, clean and lubricate the system back to the pedal.
Whilst your hands are a bit manky; tug, pull, rattle and shake other shit on your bike. Tighten, replace, repair or moan as neccessary. Thumbs Up
PostPosted: 02:51 - 10 May 2015    Post subject: Reply with quote
https://www.mandp.co.uk/productinfo/570806/Workshop/Bike-Lifts-and-Jacks/Big-Red-Jacks
Worked fine for the Savage, just sold it to a mate with an XVS1100, since the Bullet has a centre stand. £30 well spent.
Copycat73
PostPosted: 10:16 - 10 May 2015    Post subject: Reply with quote
it may be indicative of a problem as yet unknown..
that's why it would be prudent to investigate any brakin issues no matter how trifling they seem.
caveat emptor
talkToTheHat
PostPosted: 17:35 - 10 May 2015    Post subject: Reply with quote
I'll get it looked at.
Major Dross, calm down, I'm not bawwing at you.
Lifting the 535 is a ccomplete batch as most cheap portable solutions don't work. pit stands, abba stands, small scissor jacks and cruiser jacks that rely on frame members underneath the engine do not work well.
That I know this is a major issue and I need to make arrangements for assistance does not mean I do not know how to disassemble a braking system. I'm quite happy doing drum brakes on cars. For that I need a trolley jack and some axle stands, which are far easier procured.
Yes I need to sort my life out and get a bike that is less of a batch, or secure an area for work and tool storage. I'm working on that.
Andy_Pagin
PostPosted: 18:33 - 10 May 2015    Post subject: Reply with quote
Clean it out thoroughly with meths, including the shoes, it's amazing how much seemingly non-existent crap that stuff can shift.
Copycat73
PostPosted: 18:45 - 10 May 2015    Post subject: Reply with quote
have you considered a Folding Engine Crane Hoist Question
https://www.ebay.co.uk/itm/Mechanics-2-Ton-Professional-Folding-Engine-Crane-Hoist-Lift-/331547895015?pt=LH_DefaultDomain_3&hash=item4d31cb64e7
caveat emptor
talkToTheHat
PostPosted: 20:00 - 10 May 2015    Post subject: Reply with quote
That could be just the thing. I might know someone who's got one. Will consider getting my own once the living/working area is sorted.
pompousporcup...
PostPosted: 22:15 - 10 May 2015    Post subject: Reply with quote
where are you based? I have a folding crane good for 2 tons you could borrow if needed..and aren't too far
talkToTheHat
PostPosted: 03:15 - 13 May 2015    Post subject: Reply with quote
Doncaster or thereabouts. Guessing by the yellow dot on your profike that makes me a bit far away. But thanks for the offer.
talkToTheHat
PostPosted: 21:11 - 10 Jun 2015    Post subject: Reply with quote
Was checked at the garage yesterday as the bike was in for fork seals. Apparently EBC pads make all the dust in the world. Greased carefully and reassembled. Quiet now.
Apparently there was nothing to worry about other than the embarrassment factor of having breaks louder than my exhaust, and having a drum brake.
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.26 - MySQL Queries: 16 - Page Size: 122.41 Kb
