Possible centre seal failure?
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 21:10 - 10 May 2015    Post subject: Reply with quote
Possible but more likely that you holed a piston.
stirlinggaz
PostPosted: 21:29 - 10 May 2015    Post subject: Reply with quote
Hi,
Seeing as you've been through the basics of spark & fuel, what about compression?
Takes 5mins to test.
then I'd be whipping the head off to see what damage I had done while thrashing it Very Happy
cheers,
GAZ
stirlinggaz
PostPosted: 22:09 - 10 May 2015    Post subject: Reply with quote
[quote="NKVD fan]
It didn't seize, and there is enough blast out the plug holes to lead me to think the pistons are functional enough, but a compression test wouldn't show a leaking crank seal anyway.[/quote]
Hi,
yes im aware compression test wouldnt rule out a failed crank seal but why would you presume it is the crank seal thats at fault, before you have even ran through the basics?
Like I said it takes 5mins to test compression, properly. Fuel, Spark then compression.
if you have them all THEN its time to dig a bit further.
thats the normal sequence for me. After fuel, spark & compression I would start at the top end & work down.
cheers,
GAZ
stirlinggaz
PostPosted: 17:14 - 11 May 2015    Post subject: Reply with quote
NKVD fan wrote:
Quelle surprise. Compression is 110 psi, 115 other, i.e. spot on.
It's eaten a crank seal, theres no pull through the carbs when it's cranked over.
hi,
i dont know your bike, but that seems kinda low to me.
every 2t i have had, ideal compression has been around 150psi & anything around 100psi & i would be looking at replacing the rings at least.(as an example nsr should be 156psi(+/- 28)
I would be stripping the head off to have a look anyway & if i was going as far as replacing seals on bottom end, i would use the opportunity to freshen up top end at same time.
but you know your bike better than anyone.
if your 100% convinced its the crank seal, time for strip down.
good luck!
cheers,
GAZ
bypass2
PostPosted: 00:03 - 12 May 2015    Post subject: Reply with quote
float heights or floats damaged or floats sticking letting to much fuel in
bypass2
PostPosted: 15:15 - 12 May 2015    Post subject: Reply with quote
[quote="NKVD fan"]
Plugs are bone dry even though carbs are full. Read carefully.[/quote
Did read carefully. Had similar with my x5. Wont say no more.
ZebraDriver
PostPosted: 17:49 - 12 May 2015    Post subject: Reply with quote
Snapped woodruf key - sparks happening at wrong time
PostPosted: 19:07 - 12 May 2015    Post subject: Reply with quote
Block the inlet, block the exhaust, run a leakdown. You'll soon know if that seal is gone.
stevo as b4
PostPosted: 19:45 - 12 May 2015    Post subject: Reply with quote
Would you do the leak down on one pot though and listen for air escaping out of the other pipe or plug hole?
The only other thing I can think of if Blue isn't 100% certain it's a crank seal failure on the centre main, would be a possible weak spark/ or coil breaking down under load, (i.e it plugs spark out of the bike but not under the compression pressure?
It's funny for a coil to suddenly break down though is it not?
How many miles have you done on it now, and was the crank re-built when restored?
Unless the bike had been dry stored for a year or more after the re-build with no oil used during assembly, I can't see how a new or sound crank seal would suddenly go like that?
The usual story with stored dried out strokers is that they often start and run ok when first re-commissioned, but after a few miles the crank starts tearing up the dry/perished seals and you lose crank compression or get an air leak and runaway revs.
As you said though if it wasn't a blocked carb/fuel supply fault then there are few other things that would cause a twin to stop running on both cylinders?
PostPosted: 19:50 - 12 May 2015    Post subject: Reply with quote
Yep, the only way through is by gasket or seal so if you pressureise one side and it escapes from the other it's tear-down time.
PostPosted: 20:47 - 12 May 2015    Post subject: Reply with quote
No surprise then if the seal is cocked the rotation of the crank will tend to pull the lip sideways. Add a bit of case pressure and it might have turned the lip over.
It wouldn't be that hard to add some kind of stop for the seal to rest against.
Major Doss
PostPosted: 03:56 - 20 Sep 2015    Post subject: Reply with quote
I reckon OP's main seal is shagged. Laughing Well done on tearing it down/identifying. Wink
PostPosted: 22:51 - 20 Sep 2015    Post subject: Reply with quote
I didn't see this at the time it was first posted but yeah, a really frustrating and difficult to diagnose fault you only get on multi-cylinder 2-strokes.
I've had it before on Jawas. They have a bolt-together mechanical centre seal around the centre main that has to be heat-fitted on reassembly.
Usually comes on more gradually. A reluctance to start, sometimes starting by introducing fuel or bumping for a faster turnover then ok once they're running. Gradually gets worse and worse until they won't start at all.
You check the engine and everything seems ok with the fuelling, spark, air supply and compression.
As the OP found, the main signs are a) Dry plugs despite monumentally long periods kicking over and even after introducing fuel directly through the inlet port. and b) Almost total lack of vacuum through the carb(s).
The latter being the clincher, you would normally hear a distinct sucking induction noise with the airbox rubbers removed and it should such the palm of your hand against the choke of the carb. Fit balancer guages and they'll read nil or next to nil. Engine just swapping the same charge of air back and forth between the two sides.
stevo as b4
PostPosted: 18:16 - 21 Sep 2015    Post subject: Reply with quote
Well done and well diagnosed to Blue anyway!
I suppose this is one of the few engine faults on a twin that could cause both cylinder's not to run too?
What a bummer though on a 700mile old engine, having to strip a nicely re-built bike down for one rubber seal right the in the deepest depths of the motor.
The last post was made 10 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 133.83 Kb
