Yamaha Dragstar Wont start
Tuxik
PostPosted: 13:11 - 12 May 2015    Post subject: Yamaha Dragstar Wont start Reply with quote
Hey
I got a Yamaha Dragstar 650cc that will not start. When i press the start button nothing happens. The lights turn on, but nothing else. I cant hear the pump working or the relee kicking in when i press the start button.
I have checked the batteri, and thats fine. I have also replaced the Start-relee and the main relee with no luck.
I have tested the starter by by-passing it to the batteri, and it works aswell.
Need help! Can it be the CDI box?
Thanks
PostPosted: 13:35 - 12 May 2015    Post subject: Reply with quote
Check that you've got 12v+ at the terminal of the starter relay that receives the cable from the battery. Actually check it with a meter.
Press the starter and check that you've got 12v+ at the 2nd starter relay terminal.
Check that you've got continuity between the 2nd starter relay terminal and the starter motor.
At most two out of three of these can be true.
CaNsA
PostPosted: 13:36 - 12 May 2015    Post subject: Reply with quote
Kill switch?
Tried pulling the clutch in when starting?
Tuxik
PostPosted: 15:02 - 12 May 2015    Post subject: Reply with quote
CaNsA wrote:
Kill switch?
I have tried everything. I have checked the Kickstand switch, Clutch Switch, and kill switch. The strange thing, is that the fuel pump dosnt kick in either
PostPosted: 15:39 - 12 May 2015    Post subject: Reply with quote
Searching, I don't see the word "fuse" on this page.
CaNsA
PostPosted: 21:52 - 12 May 2015    Post subject: Reply with quote
I do now. Thumbs Up
The last post was made 11 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 47.44 Kb
