Damper rod bolts - best way to remove?!
Dave M
PostPosted: 22:01 - 12 May 2015    Post subject: Damper rod bolts - best way to remove?! Reply with quote
Evening,
I'm changing fork seals and can't get damper rod bolts free? I've tried the broom stick down the stanchion but no joy, it just keeps spinning! I have an impact driver but hex piece isn't long enough. Any tips please? Thanks.
Raffles
PostPosted: 22:15 - 12 May 2015    Post subject: Reply with quote
Either buy a long impact hexagon socket bit or just simply drill the head off the screw.
lihp
PostPosted: 23:23 - 12 May 2015    Post subject: Reply with quote
Are these upside down forks?
If not, and they're RWU, then you don't need to split the fork to change the seals. You can carefully screw a self tapper in each side of the seal and lift it out.
Nemo
PostPosted: 23:57 - 12 May 2015    Post subject: Reply with quote
Get a long hex socket, and next time wizz it loose with the fork still assembled.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
barrkel
PostPosted: 00:00 - 13 May 2015    Post subject: Reply with quote
If you can't find a long enough hex bit (I couldn't), buy a cheap allen key of the correct size, slice the angle off it (I used a dremel), and use it in an impact socket of a matching size. Use it in combination with an impact wrench with enough juice. I've found cordless ones to be lacking in the juice department.
Also, your local friendly garage will probably do it for free if you ask nicely. I have done this also.
Dave M
PostPosted: 01:20 - 13 May 2015    Post subject: Reply with quote
Lesson learnt Thumbs Up
Dave M
PostPosted: 01:21 - 13 May 2015    Post subject: Reply with quote
Great idea. Will try that tomorrow. Thumbs Up
Dave M
PostPosted: 01:23 - 13 May 2015    Post subject: Reply with quote
I was going to ask if that was possible! Thanks.
The last post was made 11 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 54.5 Kb
