Crank shaft bearings
JustRob1991
PostPosted: 23:59 - 15 May 2015    Post subject: Crank shaft bearings Reply with quote
Whats the best way of fitting the bearings without a puller or any 'special' tool?
Thanks
Rob
SQL
PostPosted: 00:09 - 16 May 2015    Post subject: Reply with quote
I used a socket on the outer race
JustRob1991
PostPosted: 04:42 - 16 May 2015    Post subject: Reply with quote
Ive been reading and watching videos on youtube and they say freeze the bearings and crankshaft and then heat the casing up with a heat gun.. dunno if this technique will work though
PostPosted: 09:01 - 16 May 2015    Post subject: Reply with quote
Bearings in the freezer to make them shrink slightly, crankcase in the oven to make it expand slightly. Drop the bearing in square so it goes in first time then tap it home with a big socket or piece of tube that bears against the outer race.
Snod Blatter
PostPosted: 14:16 - 16 May 2015    Post subject: Reply with quote
If what you're trying to do is put a main roller bearing in a crank case (it's hard to tell) then I have tried the bearing-in-the-freezer, heatgun-on-the-case trick and it didn't go very well. The bearing went about half in and then got stuck solidly.
I took it to a local engineering firm and the guy just whacked it in the rest of the way with a leather hammer, I felt pretty silly!
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
smegballs
PostPosted: 14:42 - 16 May 2015    Post subject: Reply with quote
and there I was thinking they would be using presses and mandrels..... Laughing
PostPosted: 18:13 - 16 May 2015    Post subject: Reply with quote
Needs moar heat.
In the oven until the oil starts to smoke.
Do it when the wife is away for a while or buy a cheap second hand oven off ebay (really, they are very cheap) and do it in the workshop. Handy for painting jobs too, gets your piece totally dry and pre-warmed.
JustRob1991
PostPosted: 19:34 - 16 May 2015    Post subject: Reply with quote
I've put the crank and bearings in the freezer going to leave them there for 24 hours, I'm going to try heat the casing up either in the oven or blow torch. Very Happy Very Happy
I don't see the point in buying a crankshaft installer tool when I'll only be using it once. I won't be doing this all the time, it's been a pain in the arse up to now.
Cheers guys...
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 56.15 Kb
