GS500 Front Pads Retaining Pin
b422063
PostPosted: 04:12 - 17 May 2015    Post subject: GS500 Front Pads Retaining Pin Reply with quote
Shitty Suzuki part quality! My poor winter hack which was treated with ACF50 has corrected very badly in the locations you don't want ACF50! Namely the brakes!
I need to change my front brake pads but I cannot get the pin out. Part 11.
https://images.cmsnl.com/img/partslists/suzuki-gs500-2000-euy-front-caliper_bigsue0107fig46_a84b.gif
Any ideas? I'm using Plusgas on it twice daily at the moment, but it's really corroded. I think if I cut it I'll end up with two halves stuck in there.
bugeye_bob
PostPosted: 11:00 - 17 May 2015    Post subject: Reply with quote
can you not remove the Caliper via the 2 bolts, then get your grips/pliers in the gap and rotate the pin to break the corrosion ?
orac
PostPosted: 11:38 - 17 May 2015    Post subject: Reply with quote
have you tried heating the area, failing that you will have to cut it off and re-drill the whole replacing the pin afterwards
b422063
PostPosted: 10:54 - 18 May 2015    Post subject: Reply with quote
Reluctant to try heat with the seals in close proximity. I may end up having to remove the caliper and splitting it.
I remember why I wanted a CB500 instead of a GS500.
orac
PostPosted: 19:08 - 18 May 2015    Post subject: Reply with quote
you cant split the gs500 front caliper
Fizzer Thou
PostPosted: 10:41 - 19 May 2015    Post subject: Reply with quote
In the past I have drilled through from the opposite side of the pin and knocked it through with a punch.I then installed a longer pin.It is only there to hold the pads in place and all of the braking force is on the much bigger pins and where the pads seat in the caliper.
Always have a 'Plan B'
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 46.98 Kb
