 davetherave51 L Plate Warrior
 Posted: 19:04 - 17 May 2015 Post subject: |
It might be worth checking the parts lists on CMSNL, Ron Ayers, Cornwall Kawasaki, etc to check the part numbers of the spacers.
Assuming the forks are not bent I would suggest the first thing to check is how far the forks protrude through the yokes. Also that the forks are parallel (ie, loosen off the pinch bolts on the top yoke, slightly loosen the front wheel spindle and then bounce the front suspension up and down a few times, then retighten everything).
Beyond that, does it feel odd all the time? Or only when you are turning the bars (check steering head bearings). When cornering? When just turning in to a corner?
It is worth checking other things such as the fork oil, springs, etc. If the front end you have fitted is 2nd hand then entirely possible that the previous owner of it has used stupidly thick / thin fork oil, or too much / little oil and screwed up the resulting handling.
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
