What is your fastest erection time?
Bike Chat Forums Index -> Touring & Exploration Goto page 1, 2  Next
Pigeon
PostPosted: 22:47 - 17 May 2015    Post subject: What is your fastest erection time? Reply with quote
Tents. Do you have, or know of, any basic tents which can be put together in less than 5 minutes.
I'm thinking 4 pegs, 2 poles and done.
I have one, it's a Vango Tempest 200. It's incredibly compact and weighs nothing. It has loads of clever design features, has always been dry and can handle a good amount of wind. I'm genuinely very impressed with it.
However, it has 3 poles, a ground sheet, 8 corner pegs, 4 guy pegs, a fly sheet.
Apparently it can be put up in under 10 minutes. Always takes me nearer 30 I think!
It's fine for pitching and using as a base. But I would really like something quick and dirty. Something where the stop each day is a different site and after many hours in the saddle the last thing you want to be doing is titting about with umpteen bags of poles, pegs, sheets etc Equally to get going in the morning, 5mins and off.
I really like the idea of the pop-up tents, but with a compacted diameter of 100cm I would struggle to fit that onto bike and bomb along at 90+ without it flying off like Oddjobs hat Smile
Suggestions appreciated Thumbs Up
delsol
PostPosted: 23:09 - 17 May 2015    Post subject: Reply with quote
https://www.decathlon.co.uk/2-seconds-easy-i-pop-up-tent-1-man-green-id_8302226.html
Only 61cm diameter:
Pigeon
PostPosted: 23:34 - 17 May 2015    Post subject: Reply with quote
That looks pretty good, have you used one?
At 60cm, I could sit that vertically against the back of the topbox and run a bungee around the base of the topbox, that should keep it in place.
Cool, thanks Smile
delsol
PostPosted: 23:41 - 17 May 2015    Post subject: Reply with quote
Cool, thanks Smile
Ain't used one but viewed them in store often enough, really tempted but have too many tents.
Stinkwheel might be along soon, I'd trust his opinion, damn good spec tent imo.
flikers
PostPosted: 07:21 - 18 May 2015    Post subject: Reply with quote
Me and my mate use a three man pop up tent when in Germany.
Less than 5 minutes to get up, 15 minutes to get back in its bag.
recman
PostPosted: 10:55 - 18 May 2015    Post subject: Reply with quote
I have a Regatta pull up tent I used for the first time last year.
Most excellent in some pretty heavy rain and extremely quick to erect/take down.
I'd say from unpacking to habitable is definitely less than 5mins, more like 3.
Pack away probably 7-8mins and that's a noob camper with no practice.
Comfortably fits a double inflatable mattress with room for all my shooting gear.
PostPosted: 12:59 - 18 May 2015    Post subject: Reply with quote
The only fault I have with my queshqua 1 man tent is that rain can get in when you open the door.
I believe they have made a little "peak" thing on the newer models to help prevent this.
Plenty of room inside for me and my bike gear. You couldn't cook in it, porch is practically non-existant. The pack size is a bit big still but not totally unmanageable, it's narrower than the bike with panniers fitted. Double skinned so midge proof but also not a total sweat-box like the single-skinners.
With practice, my Banshee 200 could be put up in a very short time. 2 poles, 12 pegs as I recall. In reality it is smaller than the popup but pack size is very neat.
Northern Monkey
PostPosted: 13:18 - 18 May 2015    Post subject: Reply with quote
I can get a vango tempest up in less than 10 minutes. It's just a matter of practice.
Keep the inner and outer together, snap the poles together, push them though, peg out the back, then peg out the front, then the guys.
Poseidon
PostPosted: 14:20 - 18 May 2015    Post subject: Reply with quote
Gelert vertigo. Weighs very little (less than 3kg if memory serves). Inner and outer pitch as one so the inside stays dry if it's raining when you put it up. But the real gem is how you erect it. Peg 4 corners, expand the attached telescopic poles (2 of), peg the guy ropes, peg the remaining 10 or so points on the outer layer and climb in. My record is 132 seconds, but that was not long after breaking my collar bone so didn't have full use of my left arm. Confident I could it up in under 2min with a bit of practice.
Putting away is pretty quick too. Undo all the pegs, collapse the poles, couple of natty folds and roll it up around the poles. Plenty of space inside, opens up in 4 different directions so you can dodge the wind even if it changes direction after you've pitched up and it's quite cheap now that it is old stock. Very waterproof from what I've found as well.
Hth
Edit:
Other half reminded me that I did once get it up in a minute and a half. So yeah, very quick to pitch. Have a look on sports direct, they were doing then for 40quid or so.
1977 Honda CG125
Pigeon
PostPosted: 22:20 - 18 May 2015    Post subject: Reply with quote
Thanks all, much appreciated. I've decided to go with the Queshqua 2-man tent. It's only 5cm wider packed down than the 1 man.
Planning on using this in Ireland, never been but hoping to go with some BCF people in August, then there is the BCF BBQ immediately after (on the way home in fact). So it's a week of camping at different sites each night potentially. £45 and it should save me huge amounts in hotels / B&B costs.
The Gelert Vertigo looks halfway between the two (Tempest 200 vs Queshqua 2 second). It's pack size would make it easier to carry, but I'm going to try the pop-up approach.
Recman, which Regatta was it out of interest?
recman
PostPosted: 22:36 - 18 May 2015    Post subject: Reply with quote
One of these but I only paid £40 for it in an Argos sale last year.
Doesn't look like they sell it any more.
https://www.ebay.co.uk/itm/Regatta-Deluxe-4-Man-Pop-Up-Tent-/371262266694
Northern Monkey
PostPosted: 09:43 - 19 May 2015    Post subject: Reply with quote
Pop up tents are OK as long as it doesn't rain and isn't windy, as they leak and fall over.
Pop up tent's are ideal if you want to camp in your living room. Not much else
Of all of the tent's discussed in this thread, the vango tempest is the best, especially when you are going to be carrying it on a bike. Just learn to put it up a bit quicker. and keep the fly and inner together when you pack it up.
PostPosted: 11:06 - 19 May 2015    Post subject: Reply with quote
Queshcua ones don't.
Massive hydrostatic head. Utterly waterproof and very wind stable if you peg out the guyropes.
I've camped in mine in some diabolical weather.
Nobody died this night, two were in queshcua popups. Even with the extra 6" of drifting snow that fell.
https://i48.photobucket.com/albums/f216/stinkwheel/cimg0473.jpg
delsol
PostPosted: 12:26 - 19 May 2015    Post subject: Reply with quote
Quechua pop-up has 2000HH, it won't leak.
For strong winds/gusts I would guy it out fully.
For extra stability for bad conditions I would leave permanently attached extra guy lines so that I could batten down a bit extra, I leave extra guys ropes on all my tents, takes up tiny space/weight.
Pegs and guy ropes:
https://www.poundland.co.uk/summer/camping-and-festivals
Alpineandy
PostPosted: 00:44 - 25 May 2015    Post subject: Reply with quote
0.3secs.
But it was a misunderstanding. Her sister was only joining us for a threesome 'lunch-wise' Embarassed
Oh, sorry. another misunderstanding.... Embarassed
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
PostPosted: 01:04 - 25 May 2015    Post subject: Reply with quote
https://i.imgur.com/lJGijdp.jpg
Tent at the front takes next to no time to put up.
It turned out to be a good place to get to watch local wildlife.
https://i.imgur.com/bi3bSmm.jpg
mentalboy
PostPosted: 04:13 - 25 May 2015    Post subject: Reply with quote
Terra Nova, Laser Competition 1, goes up real fast, packs small, sleeps two good friends ( Wink ) and with titanium pegs (personal upgrade) weighs well under a kilo - ideal for carrying on a bike Smile
Make mine a Corona.
PostPosted: 11:33 - 25 May 2015    Post subject: Reply with quote
I've always considered pack size rather than weight to be the most important think for a motorcycling tent. Within reason, weight is irrelevant, I'm not carrying it, the bike is.
mentalboy
PostPosted: 20:46 - 25 May 2015    Post subject: Reply with quote
Not very well worded on my part....packs into a nice small space, I usually chuck it in my top box with loads of space to spare for other things like sleeping bag, stove, etc Very Happy
Make mine a Corona.
J4mes
PostPosted: 21:11 - 25 May 2015    Post subject: Reply with quote
I have one of these https://www.amazon.co.uk/Gelert-Tornado-Man-Tent-Excalibur/dp/B00132D902
And after a bit of practice at home, I took it to the Pyrenees for a weeks off road jaunt and could erect it in 5 minutes, and drop/ pack it in around the same time.
Northern Monkey
PostPosted: 21:17 - 25 May 2015    Post subject: Reply with quote
Nice tent, but £250 Shocked
PostPosted: 21:43 - 25 May 2015    Post subject: Reply with quote
Carried this tent on the bike shown:
https://www.youtube.com/watch?v=uWGWX8wibz4
Goes up and folds down in seconds. No pegs needed in normal conditions - just chuck some kit in.
This is a 'blackout' version which does work pretty well at blocking light compared to 'normal' tents.
chickenstrip
PostPosted: 22:00 - 25 May 2015    Post subject: Reply with quote
Yeah, they're really designed for walking/trekking, hence expensive, lightweight materials (and paying for the name Rolling Eyes) Similar thing to my Vaude. They do transfer across to biking well, but I wouldn't spend that much purely for biking, and have other, cheaper options for that.
The Vaude also goes up with inner and outer together. I'd at least look for something that pitches outer first, so you can quickly throw it up if you arrive at your destination in pissing rain. Chuck kit inside, dive in out of the weather. Can then fit the inner later in a break in the weather.
mentalboy
PostPosted: 22:47 - 25 May 2015    Post subject: Reply with quote
Yup, true but I have a budget for one good tent rather than several shite ones that only last a few outings (Is the VauDe much cheaper, that's also a good manufacturer?) Generally with tents if you want something that'll last well it means better quality materials which you will pay a premium for. If you don't mind weight and can do a bit more size, the Quaser is an awesome bit of kit (and has been for many years, although the more modern models are not as well constructed as the originals)
...And it means I can tour on the bike as well as park it up out of the way and go native in the hills.
I've rigged it to pitch in about 2 1/2 minutes and having the inner fixed (it can be pitched separately) to the outer means that it's not going to get too wet unless it's proper hammering down or you haven't practised in a dry back garden beforehand!
Make mine a Corona.
chickenstrip
PostPosted: 22:59 - 25 May 2015    Post subject: Reply with quote
mentalboy wrote:
Yup, true but I have a budget for one good tent rather than several shite ones that only last a few outings (Is the VauDe much cheaper, that's also a good manufacturer)
No, the Vaude wasn't cheap, but I bought it specifically for hill/long-distance walking. I'm not getting any younger so I needed something very light, and it fitted a lot of other criteria I was looking for. Certainly have had my money's worth from it (although a mouse or something chewed a hole in the inner to get at a choccy bar - bastard! Laughing ).
With the modern lightweight materials, I found it doesn't really matter if it all gets a bit wet. A few minutes pitched in dry conditions and it's dry as a bone.
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 138.91 Kb
