Honda CBR600RR 2003 Bouncy Idle When Held at 5500 rpm only
ian505050
PostPosted: 20:07 - 18 May 2015    Post subject: Honda CBR600RR 2003 Bouncy Idle When Held at 5500 rpm only Reply with quote
Hi,
I am hoping someone on here can offer some assistance with a problem that i have with a CBR600RR 2003 that i recently bought and refurbished.
The previous owner rode the bike to my house and i basically stripped it to a frame, engine and wheels as i noticed many nuts and bolts were loose on the bike after it had been delivered.
I went over the bike with a fine tooth comb as i found brake disc bolts loose, the nose cone had 1 loose bolt holding it together and when the guy was riding the bike to my house the nose wobbled up and down about 3 inch.
Anyway...
After rebuilding i took the bike for a test ride to look for faults or areas for improvement.
My main issue is that the bike has a bouncy revs sat at 5500rpm only.
It pulls through the revs fine but its not possible to hold the revs at 5500 rpm weather the engine is hot or cold. This makes it difficult to ride when going round a sweeping corner as it unsettles the front end as it feels like you are constantly on and off the throttle slightly.
After a little research the honda workshop/tecnical mnual states that at 5500 rpm is when a second set of injectors kick in which matches the rpm when i have my issue. mmmmmmmmm....
I think the previous owner failed to mention the fault which is not a problem as i assume buying a bike private is going to have issues half the time anyway.... so sold as seen etc....
Oh.... just to confirm the bike rides perfectly fine apart from this, does not back fire and idles perfectly. Its got 20k on the clocks and service history is unknown.
A few snaps... Smile to follow
PostPosted: 20:09 - 18 May 2015    Post subject: Reply with quote
How can you have any sort of idle at 5500rpm?
ian505050
PostPosted: 07:57 - 19 May 2015    Post subject: Reply with quote
I used the wrong word, it will not rev smooth at 5500 rpm
PostPosted: 08:28 - 19 May 2015    Post subject: Reply with quote
All the emissions/noise tests are done at 5500rpm...
Does it have an aftermarket exhaust? Aftermarket air filter? Any other engine mods?
Fizzer Thou
PostPosted: 10:37 - 19 May 2015    Post subject: Reply with quote
Balance the butterfly valves after checking the valve clearances and spark plugs.
Always have a 'Plan B'
ian505050
PostPosted: 18:00 - 19 May 2015    Post subject: Reply with quote
It has a PipeWerx exhaust fitted and i dont think any engine mods have been done. Its also got the standard air filter as i have just replaced it.
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150507_231440_zps0o3aagod.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150512_231505_zps2tnaig8o.jpg
This is how it looked when i took it for a test ride
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150517_140618_zpsohnzxdfl.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150517_140630_zps4jwjfbfj.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150517_140707_zpscz8xnfev.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20150517_142409_zpswkiljd2f.jpg
ian505050
PostPosted: 18:02 - 19 May 2015    Post subject: Reply with quote
I will have a look into that.
Valve clearances? Could that really have this affect?
Yer... i guess spark plugs are easy enough to check.
Thanks.
orac
PostPosted: 18:06 - 19 May 2015    Post subject: Reply with quote
is the ECU throwing any code that may shed light, I presume all the injectors are working correctly?
ian505050
PostPosted: 18:32 - 19 May 2015    Post subject: Reply with quote
I dont have any warning lights when i start the bike up. I have check the workshop manual so can confirm my clocks dont show any issue.
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 63.93 Kb
