What material for drifts
orac
PostPosted: 17:53 - 19 May 2015    Post subject: What material for drifts Reply with quote
I have got to do the front wheel bearing soon and cant find what I used as a drift (think I may have barrowed one) the last time I did some.
so what the best material for general purpose drift. I was thinking aluminium (10mm bar), but it doesn't matter about not damaging the old bearings and I cant think what else I would use such a drift for.
both seem to be around the same price on fleabay for 10mmx200mm
Aff
PostPosted: 17:56 - 19 May 2015    Post subject: Reply with quote
I use concrete rawlbolts and an extension bar. Hit them back in with a socket.
Electric Bike Project
orac
PostPosted: 17:58 - 19 May 2015    Post subject: Reply with quote
so steel then. also the manual suggest using the old ones as a drift for knocking the new ones in - go suzuki
c_dug
PostPosted: 18:06 - 19 May 2015    Post subject: Reply with quote
Depends on the purpose, I've used brass in the past because it's nicely malleable and I only had a small lip to catch the drift on. The brass tended to bite more than the steel I tried before, which tended to skip off of the bearing.
In an ideal world you wouldn't use any sort of impact to get bearings into place, far better to use some threaded rod, chunky washers and a couple of nuts to press bearings in if possible. (by the go Suzuki I'm guessing you might already know this bit! Laughing).
Stalk
PostPosted: 18:34 - 19 May 2015    Post subject: Reply with quote
[url] https://www.toolstation.com/m/part.html?p=44554[/url]
For this price you can't go wrong. I have this set and they are OK, use a socket slightly smaller than the bearing to gently drive the new one in square.
Taught2BCauti...
PostPosted: 19:43 - 19 May 2015    Post subject: Reply with quote
I have a selection of home-made drifts for different jobs.
Offcuts of 15mm and 22mm copper tube.
Old inlet and exhaust valves with the heads cut off (make good centre-punches too).
Offcuts of brass and aluminium rods of various diameter.
Blocks of wood that have been cut out of 3" x 1" with a hole saw (for seals).
Old imperial sockets from an impact wrench set.
Masonry nails with the point ground off.
Offcuts of 'AllThread' threaded rod.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 19:47 - 19 May 2015    Post subject: Reply with quote
I use a steel punch/drift.
Brass works too but you'll have to dress the edge more frequently so it gets a grip.
Aff
PostPosted: 19:59 - 19 May 2015    Post subject: Reply with quote
Or use a rawlbolt so you dont have to faff around with getting the drift on the 1 micron of visible edge of the bearing.
PostPosted: 20:11 - 19 May 2015    Post subject: Reply with quote
For bearings I use a steel drift, For a mild steel pin or whatever I'll use a bronze or copper drift. Occasionally for something that absolutely must not be marred I'll try aluminium.
if you use a softer drift on wheel bearings - or heaven forbid a screwdriver/chisel - you risk turning the edge then on the next strike burring the bearing seat.
Blue_SV650S
PostPosted: 20:18 - 19 May 2015    Post subject: Reply with quote
I just use extension bars from my socket set, probably not in the textbook for use or doing them any favours, but certainly does the trick! Thumbs Up
orac
PostPosted: 08:57 - 20 May 2015    Post subject: Reply with quote
those are definitely worth a look.
thanks all your advice has been very helpful
The last post was made 11 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 70.01 Kb
